dfwmediagroup
- Feb 25, 2014
at Mike,
I had a pre ARC ref5se with the XA100.8: I odnt like this combo. -> sold the ARC ref5se and again a XP20, now I go see t replace the Pass XP20 with a GrandiNote Domino preampli that with the Magnetosolid® construction system sound amazing. I have tried this pre with VTL, ARC REFse, REF10 nd REF40 , Pass XP30...but no way: this Domino is a step up. (GrandiNOte was present in Las Vegas CEDIA, in Monaco MOC trade show,...)
Tubes or Semiconductors? Magnetosolid®.
The name of this technology borns from the combination of "ferromagnetic" with "solid state".
Solid-state components are used in typical circuits for tube amplifiers..
We managed to combine the advantages of solid state and tube amplifiers, overcoming their respective limitations.
The result is a tight, precise and dynamic sound, yet gentle, airy, warm and pleasant: natural.
All polarizations are in Class A and without feedback.
All low signal stages are direct coupled: without capacitors.
For every device, we use a dedicated indipendent power supply circuit.
Each component is carefully selected.
When you listen Grandinote, you forget to listen tubes, you forget to listen solid-state, you listen only music.
A refinement of Magnetosolid® technology is represented by the use of precious ferromagnetic components capable of bringing the listener the entire slightest nuances of the musical message, combined with a disarming naturalness
This new technology has created a new line calledMagnetosolid-VHP; the excellence we believe in sound reproduction
.5 serie XA is a very good "tube sound" amplifie...make pleasure, listen with a lot of details at very low volume too well a lovely sound.
the .8 is more "fast",sound more "modern" as Pass roduct sound very detailed (but a little minus from the .5), the LF are better comtrolled and the Mid&HF are "different vs the XA100.5 (now I use the XA100.8)
at dfvmediagroup the X250.8 like the X250.5 is sure a great amplifer. (in the 250.5 the sound was very good and was better vs. the 350.5)
sure your A70 Accuphase is another world and sound vs. the Pass 250.8, and you have a C24220 as pre! Preampli from Accu are expecially with Accu amplifier a jewels to listen each little details but with the Pass I dont know.....PLUS the Accuphase C24020 dont math with the Pass via XLR for the phase inverted. (2 hot -> Pass and 2 cold in Accuphase gear)
at the end if I sell the XA100.8 i go with GrandiNote mono ampli Demone or always and again with a class A amplifier.
PS: I have found pair of XA160 (no .5) for a very great price (6k. $!! maybe listen and as extra with the XA100.8 they ca be a bargain....
I had the phase inverted through the entire system to Hot Pin #2 when the Pass was here. The switches on Accuphase allow you to do that, so there was no phase mismatch.
