This could be pretty interesting. I'd love to hear it.
http://www.oppodigital.com/sonica-dac/
SPECIFICATIONS
Designs and specifications are subject to change without notice.
[TABLE="class: spectable"]
[TR]
[TD="colspan: 2"]
General[/TD]
[/TR]
[TR]
[TD]Dimensions (W x H x D) [/TD]
[TD]10.0 x 3.0 x 12.2 inches, 254 x 76 x 360 mm[/TD]
[/TR]
[TR]
[TD]Weight[/TD]
[TD]10.4 lbs, 4.7 kg[/TD]
[/TR]
[TR]
[TD]Power Supply[/TD]
[TD]AC 110-120 V ~ / 220-240 V ~ 50/60 Hz[/TD]
[/TR]
[TR]
[TD]Power Consumption[/TD]
[TD]30 W (operation), 0.5 W (standby)[/TD]
[/TR]
[TR]
[TD]Trigger Input[/TD]
[TD]3.5 V - 15 V, 10 mA minimum[/TD]
[/TR]
[TR]
[TD]Trigger Output[/TD]
[TD]12V, 100 mA maximum[/TD]
[/TR]
[TR]
[TD]Operating Temperature[/TD]
[TD]41°F - 95°F, 5°C - 35°C[/TD]
[/TR]
[TR]
[TD]Operating Humidity[/TD]
[TD]15% - 75% No condensation[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
USB Audio Input (USB B Type)[/TD]
[/TR]
[TR]
[TD]Input Format[/TD]
[TD]Stereo PCM, Stereo DSD (DoP v1.1 or native)[/TD]
[/TR]
[TR]
[TD]PCM Sampling Frequencies[/TD]
[TD]44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz, 705.6 kHz, 768 kHz[/TD]
[/TR]
[TR]
[TD]PCM Word Length[/TD]
[TD]16-bit, 24-bit, 32-bit[/TD]
[/TR]
[TR]
[TD]DSD Sampling Frequencies[/TD]
[TD]2.8224 MHz (DSD64), 5.6448 MHz (DSD128), 11.2896 MHz (DSD256), 22.5792 MHz (DSD512, native mode only)[/TD]
[/TR]
[TR]
[TD]Profile[/TD]
[TD]USB 2.0, USB Audio 2.0[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
Coaxial and Optical Digital Audio Inputs[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]Sampling Frequencies[/TD]
[TD]44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz[/TD]
[/TR]
[TR]
[TD]Word Length[/TD]
[TD]16-bit, 24-bit[/TD]
[/TR]
[TR]
[TD]2.8224 MHz (DSD64)[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
AUX Audio Input[/TD]
[/TR]
[TR]
[TD]Input Impedance[/TD]
[TD]10k Ohm[/TD]
[/TR]
[TR]
[TD]Maximum Input Level[/TD]
[TD]2 Vrms[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
USB Ports (Type A)[/TD]
[/TR]
[TR]
[TD]Profile[/TD]
[TD]USB 2.0, mass storage only[/TD]
[/TR]
[TR]
[TD]Audio Format Support[/TD]
[TD]AAC, AIF, AIFC, AIFF, APE, FLAC, M4A, M4A (Apple Lossless) ALAC, OGG, WAV, WMA, DSF, DFF[/TD]
[/TR]
[TR]
[TD]Maximum Sampling Rate[/TD]
[TD]PCM up to 192 kHz / 24-bit, DSD up to 2.8224 MHz (DSD64)[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
Wireless Standard[/TD]
[/TR]
[TR]
[TD]Wi-Fi[/TD]
[TD]802.11.a/b/g/n/ac[/TD]
[/TR]
[TR]
[TD]Bluetooth[/TD]
[TD]Bluetooth 4.1[/TD]
[/TR]
[/TABLE]
DAC Performance Specifications
[TR]
[TD]
Specification[/TD]
[TD]
XLR Output[/TD]
[TD]
RCA Output[/TD]
[/TR]
[TR]
[TD]Output Level[/TD]
[TD]4±0.4 Vrms[/TD]
[TD]2±0.2 Vrms[/TD]
[/TR]
[TR]
[TD]Frequency Response[/TD]
[TD]20 Hz - 160 kHz (+0/-2.4 dB)
20 Hz - 20 kHz (+0/-0.04 dB)[/TD]
[/TR]
[TR]
[TD]THD+N at 1 kHz (A Weight, 20 Hz- 20 kHz)[/TD]
[TD]< -115 dB[/TD]
[TD]< -115 dB[/TD]
[/TR]
[TR]
[TD]Channel Separation[/TD]
[TD]> 120 dB[/TD]
[TD]> 120 dB[/TD]
[/TR]
[TR]
[TD]Signal-to-Noise Ratio
[TD]> 120 dB[/TD]
[TD]> 120 dB[/TD]
[/TR]
[TR]
[TD]Dynamic Range
(1 kHz -60 dBFS, A Weight, 20 Hz- 20 kHz)[/TD]
[TD]> 120 dB[/TD]
[TD]> 120 dB[/TD]
[/TR]
[/TABLE]
