dev
Banned
Just to clarify - you are using one or two PS Audio P10's for your amps?
P10's are power regeneration vs my APC which I think is power conditioning?
The Entech line noise analyzer I bought on ebay for $70 - might be the best $70 I spent. I was aghast at the amount of noise even on my dedicated 20 amp circuit line. The APC S15 reduced line noise by 99.997% according to the Entech measurements. ALL my amps sound better - much better - plugged into the APC S15.
Does the P10 have battery backup? That's one thing I love about the APC. Living in Florida with our crummy Peace River Electric, we get brown outs on a perfectly sunny day. When storms come, power outages are the norm.
Lastly, I wonder - and I definitely don't know - whether some amps are much more susceptible to dirty AC than other amps and specifically, whether tube amps are more susceptible. I'm curious.
Two because of my configuration , check out their site for detailed description
P10 Power Plant | PS Audio
there are smaller ones also - you might be able to try a free audition at home, you could easily get away with only using one.
