MPW
Any tips and or ideas how to do those measurement?
I use REW (Room EQ Wizard) which is a free download. The measurement microphone I use is UMIK-1 which is $75. In a nutshell, measure the frequency response below 250Hz every 6" through the room to get a feel for the peaks and dips at various frequencies and select the position that has the smoothest response (smallest variation between peaks and dips). Of course, listen to ensure that what you are hearing matches the measurements, but it should. Then adjust speakers around new listening position. Definitely recommend the book, Get Better Sound, by Jim Smith for further details. Setting the listening position first is critical. Speaker position should always be second. Hope that helps!
