My Coming Out
Boulder doesn't make a mono amp at this level. In order to keep the timber match I'm using 1 side of my 866 set in theater mode. I hear there is a new amp do out very soon that may suit my needs. My 866 will go back to my 2 channel listening room which I am missing.
Currently my HT sounds excellent,just outstanding.
I'm sure it sounds great. You might watch for a used Boulder mono block or, bridgeable amp, or maybe even one channel of a stereo amp. Just seems a waste of an entire integrated, but I tend to be a bit OCD.
I agree. A bit of a waste of an integrated. For the time being it will stay as is until next steps. I'm curious what boulder might be coming up with to solve my problem. I would like my integrated to go back to my 2ch. I quite like the sound of that set up.
Did you have a 533 or 533h?
I had a 532h which I did not find fatiguing with a Levinson pre. My current 534 is not fatiguing but has more mid/high energy than I expected. It could have become fatiguing if it weren't for adjustments on my speakers and using a different digital filter. I am waiting to experiment with an external DAC. If I don't get the balance I like a change may be in order down the road. The 534 is a much better amp than the 532h but the 532h had a nice balance and attack. I actually prefer a slight bottom up sound but I will definitely take balanced. Top down is annoying.
A new feature I'm finding with the boulder vs levinson. The Boulder is lot less fatiguing.
There was a 532, but not sure if a 533. The 532 was more of a Levinson traditional design and around $20k. It has some issue and didn't last long.
The "h" series was built in the Crown factory having 2, 3 or 5 channels but using the same chassis. You just ordered it with the number of modules you wanted. There was even a 531h. The 532h ran about $8500.00. This was a great amp and didn't get the appreciation it deserved. This series was not a traditional Levinson design that doubled down etc. With that and being built in a different facility could be the reason. The "h" series used banks of small capacitors opposed to large can size, this gave the amp a very fast lively response. The sound had one of the flattest responses I've heard to my ear. As I mentioned above my current amp is better but there are aspects of the 532h I miss. The "h" series was in the line up for years.
I know you mentioned fatigue but I suspect that was possibly an equipment mismatch somewhere in the chain. I used my 532h for both music and movies, using JBL speakers the sound was never fatiguing to me and I don't especially like bright. I'm sure compared to Boulder the 532h was also outclassed.
I believe it is a 533H. What is the difference between the two?
Thanks for the explanation. much appreciated.
Those Cornwalls are actually 15 year old Cornscala’s, which are like the new Mk lV Cornwalls (I love ‘em) but I originally designed that room for Klipschorn’s……….I’m looking for a pair near me and not too expensive I hope!
I actually prefer the La Scala's I got over the K-horns as I auditioned both. La Scala's are a HUGE step from the CW IV's I had. But's it's purely personal opinion. They are all great speakers.
I understand if Klipsch is what you must have but if other options considered you might take a look at Volti. Really good sounding horn speakers IMO.
