Magico rack?
What would Magico recommend. one of their 50k racks or upgrading from S1 to S5 mk2?
Going from S1 to S5 Mk2 isn't an upgrade, it's a major system change which will likely call for a component change (amps at least) for full realization of the benefits of the speaker "upgrade".
A good rack should be added to a system as soon as it is feasible since it improves any and all components. But in your example of a system change I'd have to say going from the S1 to S5 would make a bigger difference than the rack if the funds aren't available for both at the same time.
I'm a Naim fan, and Naim owners frequently extol the virtues of (A) a proper rack and (B) the Naim rack. But A comes first.
The Naim rack, at about $1200 each level, is far from cheap but obviously not at the price point of Magico and others. It was thoughtfully designed in-house at Naim. I own it because it works visually in the room, and I'll take it on faith that it provides function. Many owners report its functional virtues, and editorializing on that takes one down "that" rabbit hole. I too do not have the facilities to do a listening test to racks the way I can with interconnects, power cords, etc.
It's true that unlike other components it's really difficult if not impossible to audition a rack in any practical sense. Best practice IMO is to ask for guidance a dealer and/or from other audiophiles that you trust.
All I can say is that *my* rack made *my* system sound *much* better than it ever did before.
Really? In my long association of following the Magico mantra I don't recall them being overtly critical of any of their competitors. So, where is it that Magico are calling them crap compared to Mrack?
regardless of all them positive feedback about racks….magico is calling them crap compared to Mrack
I doubt that. Never heard a word here. Magico is very professional and focuses on what they do best.
well, i read they called EVERYTHING ELSE NOT SATISFAYNG
btw, sorry, just felt a little provocative may be
Magico LLC is pleased to introduce the MRACK audio equipment stand. Over the past fifteen years countless amplifiers, DACs, servers, transports, turntables and cables have made their way in and out of the Magico listening room as we have prototyped and brought to market over two dozen speaker models. The cornerstones that have remained throughout it all are the Magico MRACK equipment stands. The MRACK was originally designed for our own internal R&D to maximize system performance where available options consistently fell short.
i think ist this...it was a month ago or so,
well, they say everthing else fell short….may be not excactely the same but for me it sounds that way
No, that's not what they're saying at all. Read it again. They are saying they've had a lot of stuff in and out of their listening room over the years, and the cornerstone has been the MRack. It is the one thing that has stayed. They make no comparison what-so-ever between their MRack and anybody else's rack.
well, skip the first part....its bla bla or actually its normal the rack to stay, just as normal as your chair or so will stay for a long period.
this it is:
AVAILABLE OPTION CONSISTENTLY FELL SHORT
They are not saying the other options were crap. They are saying they fell short of the performance expected.
Crap means not fit for purpose. Falling short means better than crap to varying degrees, i.e. somewhere north of crap and south of state of the art. Magico aim for state of the art. I would have thought that self-evident.
ok, well explained and i think you are right.
still, would you agree that they say something like the Mrack is better than anything else by far?
btw i would like to point out that i am not against if they say so
