u-sound
great if you can afford one or two and it doesnt even really matter
So.. your cheap... why dig on those who would find it reasonable?
on the chance that you are responding to me.......by posting that link, i did not mean to infer you should acquire an active shelf, more that racks matter and passive solutions are also effective. dealing with floor born resonance matters to system performance.
a passive decoupling rack such as the Magico matters as far as system performance. and if you can afford the Magico rack, you can instead choose an active shelf or two. certainly much more modestly priced effective passive choices exist. see Artesenia racks for instance. if i were in the market for the best, most cost effective passive rack, it would be my choice. not cheap, but reasonable.
as far as it doesnt even really matter, not sure what this open ended comment means. what do you refer to as 'it'?
Not only digital and analog, the most obvious example is speakers. When I added SPODs to my Magico S3, it removes any doubt for me in terms of vibration control or energy dissipation.
I’m not discussing the price, but rather his comment that it would not improve your sound. Has he compared the Magico stand to others? Has he compared any top drawer rack like Critical Mass, HRS or Artesania to a home built wood rack? Mitigating vibrations through energy dissipation or isolation is critical for achieving great sound.
and some like theyr system well tempered..the copper dissipates the heat that’s created from the vibrations/energy.
the "it" would stand for something like improved soundquality.
i mean something like buying this as a furniture and it might sound better and if not who cares.
no, i wasnt responding directly to you.....neither to anybody else and neither am i against a rack or wouldnt say there is not a topic.
its just that i hear the same thing about isolation, dissipation etc for the last 30 years and physicians delivered already so many perfect solutions for that.
every matirial in any configuration have been shown.......prices have raised, they did, they really did.....glad the designer didnt stick some swarovskis to it
