From that angle, it looks like a different industrial design approach / form factor.
That yacht keel like structure between the body and tripod base lends it a certain air of elegance, like the speaker is floating.
It also appears that the bottom of the speaker is not parallel to the floor, with the rear being higher than the front? If so, possibly to make the top and bottom plates non parallel, and reduce standing waves?
Pure speculation here too but is there a hint of suggestion that the front tapers to a narrower rear back plate? Again, to reduce standing waves and make it look more sculptural? [Then again, perhaps not, since the slightly curved carbon fibre panels will be able to break up the standing waves?]
Read somewhere that Alon said that Magico is in the business of making speakers, not furniture (hence no wood veneer and, originally, only black anodised finishes). This seems to be a slight change of approach albeit more of a form following function industrial design.
