Magico M3 Reviewed by TAS
Probably not for many reasons.
But, in past experience with the product lines of Magico. Each new series of speakers seems to be more and more musical - from what I've read, the A series might surprise us. I'm keeping an open mind.
I hardly think that anybody contemplating Q or M would end up with A.
The A is a big side-step from anything they've done in the past. Budget friendly. Sub-contracting out the cabinet manufacture. No colour or finish options. etc. But it is still a Magico, and they wouldn't do it unless it was a Magico. For all that means.
I think the A3 could upset the S1 mk2 Apple cart. I’m anxious to hear mine. Should have them SOON!!
So far, anything with “3” in it from Magico has been KILLER in the right sized room. Was listening to my S3 mk2’s today. Man, total disappearing act. Love them. M3’s are OMG good. I was listening to Anita Baker’s Rapture album and in total disbelief of what I was hearing with the accompanying MSB and Gryphon and MIT.
...So far, anything with “3” in it from Magico has been KILLER in the right sized room. Was listening to my S3 mk2’s today. Man, total disappearing act. Love them. M3’s are OMG good...
So I made the right choice then? When you are at Q3, do you go down to S3Mk2 or up to M3? I went for M3.
Agree with Magico, Gryphon and MIT pairing. Even “lowly” S3 mk1, Diablo 300 and MIT Evo One pairing sounds superb.
Had a couple of close friends join me tonight for a music jam session. They were blown away. And I finally appreciated the Rolling Stones. The Gryphon/Magico combo makes music come alive. The litmus test is do you end up listening for many hours more than what you intended. Thank you Mike.
MPODs? That’ll elevate the S3 mk2 by a notch or two.
I have the SPODs on my S5 MKII. They 'tightened' up the bass a bit, but since my speakers are on my living room floor, and that is on a concrete slab, which sits on the ground, there isn't much vibration to eliminate. I bet if I had a basement, or crawlspace, under the floor there would have been a bigger effect.
USED M3's? Wow, now that is a FIND :). I should be on the look out more closely I guess.
Used M3 are out there, I've seen 2 pairs in the past week. I was going to buy used, but they hold their value so well I decided to buy new (i.e. Nothing to be saved buying used, yet).
Or SPODs designed for the S series. I know the MPODs are effective having heard them on the MPro, but I have not heard the SPODs.
Peter, sorry I meant SPODs. I was thinking SPODs but somehow I typed MPODs. I have a set of SPODs on my S3 mk1 and I wouldn’t have them any other way.
My floor is solid marble. Do you think SPODS could make a noticeable improvement? Just some bass tightening or could there be other sonic improvements?
