Melbguy1
Guest
- Sep 14, 2016
I agree, your M3's will need atleast 400hrs to be mostly played in. During that process the bass should open up and become more solid. At that point you and your Dealer can dial in a final speaker position which should further improve the bottom end.I appreciate the thoughts and advice. I'm only slightly disappointed so far, but in the big scheme of life,this is a fixable problem. If the M3 doesn't work out in time,Im confident I can find an equitable solution with my dealer. FYI, someone from Wilson informed me that the Alexia may get an upgrade later this year. Perhaps another reason to hear the S7 if necessary.
A dear friend of mine lost a family member tonight which kind of puts high end audio in its proper perspective.
barry
If in the end you're still unhappy with the M3's in your medium-large size room, yes I'd agree the S7's would be the closest Magico speaker within your budget in size and bass output to the Alexia's. If you go down that road, my only suggestion would be to get the optional M Pods which are awesome as I'm sure you're already aware.
With the above said, I'm sorry to hear your sad news. I'm dealing with similar issues close to home, and it is difficult and humbling. Take care bro.
