Kingsrule
- May 11, 2014
you are expecting a lot from sealed boxes - won't happen.
Let's be real clear here. Please actually read my post
I'm not "expecting" anything
Another great Magico design.
I just wish they could figure a way to get their newest additions to be more sensitive, say 94-96 db while keeping their sonic signature.
That would make their speakers even more amazing!
Hi Bud,
They learned to make the cabinet using monocoque construction, which is stronger, more rigid, lighter and takes up less space than the internal metal skeleton of the M3.
Best,
Ken
I’m listening to the sealed cabinet Magico M6’s at this very moment. I am hearing some of the finest bass I’ve ever experienced in terms of impact, texture and articulation.
Ken
Ken
+1
The enclosure design is much more advanced than the M3. M3 is a bit like the Q3 is disguise - built from aluminium panels with carbon fibre 'skins' on both sides (if you take out the M3 drivers, you would see that the inside of the speaker is all aluminium, although AFAIK the side walls are no loger parallel, which is an advancement over the Q series) to make it look nice and help the dispersion.
The M6 on the other hand, is a completely different design. There are no aluminium sidewalls. The whole carbon fibre enclosure is now a monocock, acting as an enclosure with curved walls (so now if you take out the M6 drivers, you would see that the inside of the speaker is all carbon fibre, with curved walls).
M2 is basicly build using the very same technology as the M6. Getting rid of aluminium sidewalls and the accompaning aluminium skeleton, makes the speaker lighter.
If they can rip out all that machined aluminium in a M3Mk2 perhaps there will be a significant price drop? Here I am, just taken delivery of the last speaker I need ever buy and already there is talk of its replacement (and which might be much lighter and cheaper).
So you think we'll see an M1 before we see a M3Mk2? The M2 no doubt has opened up opportunities to make the M3 better.
It's expensive to machine and assemble that aluminium internal skeleton. I don't know about CF manufacturing costs, but I would think the CF in a M2/6 design wouldn't cost much more to build than what the side panels in M3 cost. So if their build price comes down, maybe MSRP of the Mk2 will come down also.
Carbon fibre monocoque is much more expensive to manufacture than the enclosure made from extruded aluminium (or any aluminium for that matter).
