Paul
Senior Member
So when is your M2 arrive ? [emoji3]I also read an impression of someone who liked the M2 more than the M3.
Still contemplating Paul![]()
So I listened to a song on the M2, Jeremy Blake - Limit to Your Love. I discussed it before but when the vibrating bass kicks in the M2 have this unbelieveable ability to throw out a holographic soundstage like I never heard and I heard the bass vibration right next to my ears as if I was wearing headphones.
I tried this on my home Sig S8 v2 which I thought had an excellent sound stage and holographic projection was surprised to find absolutely none of the similar effect, the bass was simply flat sounding coming from the speakers... the sense of 3D that the m2 produces is amazing.
Sadly I didn't play this song on the S7. I am interested to see if the S7 does the same. Maybe it was his room? But I don't think so because his room wasn't even optimal.
Would be an honor, are you a seller of avantgarde? I'd like to hear them.
James Blake, not Jeremy Blake.So I listened to a song on the M2, Jeremy Blake - Limit to Your Love. I discussed it before but when the vibrating bass kicks in the M2 have this unbelieveable ability to throw out a holographic soundstage like I never heard and I heard the bass vibration right next to my ears as if I was wearing headphones.
I think that fluttering effect is more due to power and setup than anything else... it seems like it’s due to fluctuating the phasing, not imaging in the usual sense. It pressurizes the room and tickles my ears.
I get a tickle sensation on my home system. What I heard with the M2 is different. I listened to the song my hd800 and the bass was right in my ears. This is how it sounded on the M2, as if the bass was coming from transducers right on my ears. So its more than a mere tickling of the ears.
There are two effects as I mentioned - a fluctuating pressurization of the room (the tickling) and some kind of phase effect which makes the sound seem to be coming from everywhere which your brain interprets as next to your ears or even behind you. Some of the laughter in DSOTM for example has the same effect of delocalization.
If you don't get the tickling effect it's because the speakers aren't pressurizing the room (not enough power and/or not enough woofer). If you don't get the phase effect with the sound seemingly coming from next to your ears it's most likely speaker placement issues. I get both effects on my system but I wouldn't attribute either to imaging. Holographic imaging implies you can locate sounds precisely within the sound field. Phase manipulation kind of does the opposite - it delocalizes the sound. Pulling it off depends on proper speaker placement, seating position, and sound treatment of some kind to minimize disruption from the first and second reflection points.
The room dimensions are not ideal - there are probably some significant room nodes that need to be dealt with. You might try placing the speakers a couple feet further in to the room. The subs especially will likely take a lot of trial and error and/or room treatments and DSP for best result.Any advice on placement of my speakers to mimic the same phase effect? Right now I have my sig towers slightly toed in and about 3 feet from back wall and 4 feet from side walls in a 16 foot long room, listening position is about 10 feet away. Room is 16 x 12 x 8 ft. 2 18 inch subs, one in top right corner and one in back left corner. No treatments but furniture and book cases in my room.
https://www.youtube.com/watch?v=xs1DJ3q0OTU
Thanks!
After a long absence, and not a lot of serious music listening (one of the many downsides of working too hard!), I am re-engaging with my music. Was delighted to see the M2 release and have read with interest all the reports. One thing that jumps out at me is that the M2’s bass reach (at least based on the specs) is less than the M3s and also the S3 mk2s (smaller drivers presumably). Has anyone who has heard the M2s and the M3s found the M2s lacking in bass? Appreciate that room size is a factor. Also read with interest the view that the M2s’ enclosure is more advanced than the M3s (M6s trickle-down). Aside from room size and ignoring budget (two key variables!) is there any reason why one would go for the M2s over the M3s?
The M2 is definitely not lacking in bass. It filled the 20 x 30 room at Munich beautifully. The drivers I BELIEVE are built to a higher specification than the M3 and that’s how they can get so much, so low out of just two instead of three. The cabinet is a definite advantage helping the speaker disappear. As I said to Alon, the M series outplanners the planners. Others like Alpinist have said this and I agree. The M2 is for the customer who wants to upgrade from the S3 mk2 IMHO (Larry, this means you). [emoji1787]
