Joe, are you looking for your exit speakers or just another pair to complement the Harbeths?
Hi Allen,
I'd have to say Yes and Yes.
Joe, would you consider Lansche 5.1 or perhaps the 7?
I tried to delete the second image because I didn't want to offend anyone. I can't get figure out how to. My caption was going to read "Hey Joe these come with in home setup including help bracing the speakers from the front"
I save the image first, then if you want, I'll delete it.
With her standing in front of the speakers I bet there are no standing waves or slap echo.
Joe
I say forget all of the suggestions you've read so far and go out and get yourself a pair of Bose 901's and be done with it:roflmao::roflmao:
On a serious note, get the Stradivaris:audiophile: You know you want them:exciting:
To achieve an even more extended response in the low frequencies, a third way has been added to the Prologos 2*‐ way topology, using a 7” Woofer of extreme linearity.
The Mid-*range and tweeter remain the same drivers used in the Prologos and the same drivers used in the Goldmund Apologue Anniversary.
In order to keep the high efficiency and high SPL capability of the Prologos, and additional Telos circuit is used and an exceptional 3-*way crossover is implemented in the Digital domain with full Amplitude, Phase and Time correction...
La verdad es que ya llevaban un tiempo negociando sobre la continuidad de la distribución. Por parte de DYNAUDIO, han ido cambiando estos años en sus politicas de venta, incluso sustituyendo a su “Sales Manager” para Europa. No se entiende como dejaron marchar a Robert Hagemann, el cual ha sido inmediatamente fichado por BURMESTER, y que además continúa unido con Francisco Gutiérrez de LYRIC AUDIO ELITE por un vínculo de amistad de mas de 20 años. Tambien dejaron de sumunistrar OCOS, así, sin más, cuando era el cable de referencia para DYNAUDIO, y así otros pequeños cambios que no siempre eran del agrado de sus Distribuidores.
Finalmente, y despues de 25 años, LYRIC AUDIO ELITE, según nos explicaba su responsable, tomó la decisión de dar por concluidas sus relaciones comerciales a partir del 1 de Mayo, fecha en que se comunicaría oficialmente el nombramiento de un nuevo distribuidor para España.
Por este motivo LYRIC AUDIO ELITE, con los almacenes repletos de mercancía, va a proceder a traves de su red de colaboradores, a la liquidación de todo el material que tiene en STOCK y que comprende prácticamente toda la gama, desde la serie DM, pasando por las EXCITE, FOCUS, CONTOUR S y CONFIDENCE, ofreciendo un DESCUENTO DIRECTO DEL 30 % EN TODOS LOS MODELOS hasta finalizar existencias...
Bose 901 Series X1000?
