https://audiophilereview.com/sacddvd-audio/loss-for-words-is-cd-quality-lossless-or-lossy.html
All schemes of modulation or encoding are lossy. They all truncate frequency and dynamic range to some extent that pundits will argue endlessly as to whether they are relevant. I guess the more appropriate question would be is some form of compression coding used in digital formats and whether those are lossy over and above that of the master digital format.
Absurd argument, given all encoding of sampled soundfields are lossy.
You either believe in the Nyquist theory or you don’t.
It is actually more than a theory: it is a theorem. (Theorems can actually be proven while theories cannot).
I suppose that anyone who has ever been to a live concert can easily confirm there is no such thing as a lossless recording format [emoji3].
Try ambience.
What do you mean when you say "Try ambience"?
That is one element where IHMO a lots gets lost. You could also call it atmosphere.
IMHO the main thing lost is transients, second is detail (which is where "ambience" or "atmosphere" is)
There is plenty of ambience captured in many live jazz recordings.
Once again, "CD" is a playback medium/format. Capture has exceeded 16bit and 22k for over 2 decades. With noise shaping and dither, perceived dynamic range can exceed 120. Everyone with technical literacy in the field understands this.With RBCD, it is possible to capture something close to 96dB of dynamic range
That has zero to do with digital and everything to do with the idiots in studios. Fact remains todays digital capture vastly exceeds analog antiquated technology from the 50s, in every single metric, including dynamic range.but the reality is many digital recordings aren't capturing as much dynamic range as pro tape decks did in the late 1950s.
Even funnier are those who believe analog can remotely compare to digital by any measurable metric, including dynamic range, except of course "I prefer it".The funny thing is some people believe every digital recording has 96dB of dynamic range.
I agree with the latter, disagree with former. We can certainly capture the transients. What's missing is about 90% of the soundfield (aka the ambience, etc). I've posted this numerous times, but here it is:IMHO the main thing lost is transients, second is detail (which is where "ambience" or "atmosphere" is)
yes sir, key is "perceived", based on our sensitivity vs frequency so that the noise shaping can be applied selectively. Quick link cause I've gotta run..I knew about dynamic range > 100 dB, but 120 dB?
