Thanks.
Was wondering. Does everyone use the stock protractor that comes with their arm or an after market alignment jig?
Clearaudio Alignment protractor jig & Fozgometer
Thanks.
You rang?Perhaps if Brian Walsh is reading this thread, he can chime in on his experience setting azimuth with the Feickert software.
You rang?
I've been using the Feickert Adjust+ Pro software ever since it became available, and with quite a few installations and alignments under my belt I think I'm past the learning curve. There's definitely a learning curve to it.
There's not a lot to say except it helps you really get the azimuth right, being able to minimize phase error between channels rather than relying upon equalizing crosstalk between channels, the approach taken by the Fozgometer which is less accurate since the azimuth setting at which the crosstalk curves intersect is often different from the azimuth where the phase curves intersect.
...snip...
It's also worth noting that the cartridge needs a nose-down attitude in order to achieve the desired 92 degree SRA, which I tried to set using a USB microscope. With the rear of the arm (at the pivot) all the way up we were unable to achieve 92 degrees SRA. We're working on a couple of approaches to make that happen.
Myles, I use a USB SoundBlaster to interface the output of phono stage to the computer.Thanks Brian. Did you have to add a special card to your computer to use the software?
Guess the other way is to by trial and error set the azimuth using say the Foz and then listening by ear. How much difference in adjustment do you find say using a counterweight between crosstalk and phase? Very slight rotational adjustment?
	I read Valin's article in TAS a few months back with great interest. So far all I have done is use the Feickert Protractor and my eyeball. The process looks quite involved and complex, but given the amount of money I have spent on TT, cartridge, Phono Pre, etc. I would be very happy to have a professional do the set up and allignment. I can see doing the azimuth with the Feickert software, but the SRA with a heavy duty microscope, etc. looks beyond me. Also, maybe having someone set the VTA for a few different thickness records - normal, dynaflex, 180g, 200g. It would mean coming to my home (or me hauling my VPI HRX Rim Drive to the person). I just don't know whether anyone performs these services (I'm in the SF Bay Area).
Larry
As for azimuth differences for crosstalk vs. phase response, it depends on the cartridge and probably varies by individual cartridge. It's usually within a few tenths of a degree, easily seen on the graphs.
Here is a good example. The phase response curves are on the top graph, the crosstalk curves on the bottom graph. The correct azimuth, indicated by the top graph, is -0.4 degrees (turned clockwise from horizontal when viewing the front of the cartridge and headshell), while the crosstalk curves indicate -0.8 degrees, which if used would result in almost 30 degrees of phase error. Some difference in crosstalk is much less perceptible than phase error.
Dre, thanks. I would appreciate any recommendations you have to get me started. You can PM me or I can PM you. I have had very good success with consultants helping me set up my digital ripping hardware and software and in that case, expertise and time efficiency were very well worth the cost involved.
Larry
Jay Nakamura's name comes up a lot for turntable set-up in LA/west coast circles. Randy at Optimal Enchantment can provide his contact info.
Larry
Thanks, Dan. I will give him a call. Larry
Sterling Trayle is at the house right now, starting his allignment process. Should be here all day. Will let you know how it works out. He will be doing both my Lyra Skala and Helikon Mono and also helping me with setting the VTA for both regular thickness records and 180g and 200 g audiophile pressings.
Larry
