check this out: Dynavector's Conclusion
For true hi-fi music reproduction, traditional hi-fi technology which pursues only accurate signal and replay by means of advanced digital techniques is far from the truth. The recovery of the dispersive elements contained in the original sound in a listening room is now recognised as the important factor. Conventional 2 speakers stereo does not allow for this, neither do the multi-channel systems on offer.
Dynavector has concluded that the existing 2 speaker's stereo needs at least one more pair of speakers to develop the required dispersive conditions in the listening room. After ten years of research work, we have succeeded in producing the answer to this problem by developing a SuperStereo system.
SuperStereo System
As previously mentioned, a loudspeaker radiates sounds which are non-dispersive propagation waves. It is not possible for the loudspeaker itself to discriminate between non-dispersive or dispersive sound. To discriminate between the non-dispersive and dispersive components in sound directly radiated from the diaphragm of a speaker, the environment surrounding the speaker needs to be identical to the original environment. Perfect simulation of the original recording environment is theoretically not possible. But in our many trials over several years, we have found that even an approximate simulation can produce a life-like reality from the playback of recordings much closer to the original sound.
After much research, Dynavector has now perfected a SuperStereo processor which produces numerous group delays throughout the entire frequency range. The sound so produced is played through additional speakers. The additional speakers are located so as to face the main, front speakers. The interaction of the sound between the front and rear speakers produces significant group delays in the listening room. While the group delays are not identical to those in the original listening or recording environment, the feeling of life-like reality is greatly enhanced by the use of such a system for the playback of CD's, cassettes and LP's. Even by applying the SuperStereo technique to a limited frequency range, the improvement is striking, but there are several grades of SuperStereo processors to cater for all users from the basic music lover to the most enthusiastic audiophile.
Outstanding Features of SuperStereo
1. Any normal stereo system, whether modest or top end, can be used with a Dynavector SuperStereo processor without any change of equipment or speaker setting, and connection is straightforward.
2. Normal, compact speakers are recommended for the rear pair.
3. SuperStereo works very well in any environment. Room size and acoustics are unimportant and room-tuning devices are not needed. So SuperStereo does not interfere with room decor.
4. The listening point is not limited to a centre "hot spot". Almost any position, except near to any speaker, is enjoyable.
5. The playback of music can be enjoyed with a lifelike reality not achievable with a conventional stereo system, however expensive.
6. Poorly recorded material sounds much better with SuperStereo and monaural LP's can sound even better than modern stereo recordings. Many historic recordings by great masters of the past are revived to sound like the original concert performances.
7. Even with very small systems, by using a SuperStero processor, deep bass can easily be reproduced and dynamic range, smoothness and detailed resolution are much higher than in conventional stereo systems. The purchase of expensive equipment is not necessary to enjoy the real sound of music. And there is no need to worry about obsolescence from new digital "high tech" which constantly appears on the market.
8. The ultimate SuperStereo can be achieved by a step by step add on of further processors without great expense. Expensive speakers and amplifiers are not needed.
9. SuperStereo has many applications in audio including PC music, in car entertainment systems, home theatre, professional sound systems for theatres, PA systems, synthesisers and electronic instruments, the tailoring of studio acoustics and medical therapy systems. Patents have been granted world-wide.
For all the tech stuff,
https://www.dynavector.com/essp/hi_fidelity.html
I first saw this several years ago, always wanted to hear it to see whether it lives up to what it says.
Right, only one has video. But the physics of sound is exactly the same for both. Really comes down to what one's demands for "reproduction" are.
Most "audiophiles" are actually "stereophiles". Their demands begin and end with stereo constructs. Others, like myself, are after something else, based on these
objective facts of physical reality , nothing subjective there at all. That comes afterwards.
Subjectively, stereophiles are satisfied with
frontal stereo constructs, others want something akin to
this which is physically impossible without at least (2) rear channels. 4 is the
minimum. I consider this as stereo + 2, since all mains are capable of pure stereo, the other channels can suffice for both MCH music and movies as needed. Such systems can produced
enhanced stereo as well. That's what I do with 99% of music, which is stereo. There is an "off" button if/when the effect is undesired.
Good speakers won't have any issues with reproducing whatever signals they are sent. Sad ones will.
If HT is involved, having a retractable screen is nice to keep the space between mains open for non movie listening. A wall mounted TV can accomplish the same. Or both, one for movies, the other for daily casual viewing, etc.
As with all discussions here and elsewhere, it will come down to preferences and electro-acoustic/perceptual subject knowledge. Or lack thereof.
cheers,
AJ
