Audiophilehi
I think I’m more confused now than when I 1st started this endeavor. :scratch2:
Lots to think about and tougher to listen to them all.
Lumin D2.
There are a ton of great DACs for very reasonable out there. Trust me, I tried quite a few. I also understand the budget you stated.... I tried doing the same, and I definitely can't afford the crazy level stuff that gets discussed in forums, AS included...
However, being that I went through over a dozen DACs before I finally found "the one" I do strongly recommend that you consider expanding your budget a bit, if at all possible. If you can swing a T+A DAC 8 DSD you should be good to go for quite some time, especially if you enjoy DSD. If there is any chance of you ever doing any upsampling (Roon, HQPlayer, or like me Roon feeding HQPlayer) then you owe yourself a T+A DAC.
Anyway, that is my two cents, for what it is worth....
Thanks Randy. I would love to swing for the T+A DAC 8 DSD. Maybe Mike can make me a phenomenal deal! :exciting:
$2500 would be a great deal![]()
Immediate payment if so! :exciting::exciting:
If you would like a T+A, keep looking on the used gear sites. I have seen a couple of the DAC8 used for under $3K. A friend of mine bought one used for about $2800.
And has warranty.Make sure it is the newer model (the DSD model) ...
Great choice Paul. I think you will be very pleased. Keep us updated when it arrives and your thoughts.
Enjoy Paul.
