Would like to try out some amps around a Lumin X1 and Scansonic MB3.5 B. Will do my best to describe my constraints and preferences. Just looking for any subjective thoughts or input, if you're game.
- Budget ~<$10k, new or used.
- Form factor is important. Has to be less than 18" deep, around 16" is ideal (width/height don't matter as much). Weight <80 max, prefer <60.
- Prefer a stereo amp in one chassis, but would consider monoblocks.
- Not looking for an integrated, but would consider if all else is right. Simpler the better. Lumin out to the amp; I have no other input needs.
- I listen mostly low-mid volumes, sitting about 9 feet from the front plane of the speakers. Mostly jazz, classic rock, classical (baroque, orchestral, piano), alt-country, world/eclectic. Nothing too heavy really, beyond the occasional Sabbath or Rush disc.
- I like part of @joeinid 's description of the Enleum: "an open, lit from within sound". Also: big soundstage, placement/separation precision and air, speed, a good thwack of a drum hit, vocals like they're in the room. Organic and musical.
On the list for possible rotating in:
Enleum 23r, Bakoon 41/51, NAD M2
3, T+A Amp 200, Ayre VX-R, Soulution 311, something Gryphon
(yeah, I suspect these may be very different from each other and some may be challenging to find in budget)
