Another update:
- Still using my Lumin. Tried a firmware update to get the MSB renderer module working but no luck.
- The Gryphon combo is just sounding better and better. You know that feeling you have the day after a really good live concert when you can’t get the music/feeling out of your head? It is like that.
- I swapped out the XLR interconnects (from Pandora to AE) on loan from my dealer for some MIT SL Matrix XLR 36 interconnects to match my existing set (Lumin to Pandora). A noticeable step up in SQ even with no burn in, particularly LF and HF. I didn’t take note of what the the loaned set was but dealer said they are about half the price of the MITs.
- The 3 different Class A bias modes are an awesome feature. It is like having 3 amps in one, although I find I have no need for “medium”. The “low” bias is very much like the Diablo 300 but a touch better and as mentioned above is good for crunchy/distorted guitar music. Then as you move up to “medium” then “high” bias it just gets better and better for all other genres.
Am in music heaven.
Can you clarify your comments on the MIT? Are the MIT IC’s on loan?
Lastly, the bias settings are only for limiting power and therefore limiting heat output. The low should only be used for low volume listening.
