triodesteve
- Apr 29, 2018
Yes it is the Extreme. Ethernet from the modem to Airport Extreme and ethernet back to the switch. Good idea on the Jameco..see if it makes a difference before going hog wild on pricey LPS's. The one negative of networking audio is the myriad of power supplies. A tangled web!Hi Steve,
So what/where is the router in your configuration? Its not clear to me. Is it the Airport Extreme?
I'd also recommend using a linear power supply for the switch if it is using an SMPS presently. Good and affordable ones can be obtained from Jameco in a range of voltages for approximately $11.
Thanks,
Stephen aka PC
Thanks
