Mike, I guess you have the bigger siblings on display, but you might know the answer regarding the 500 series as well. I read in a Stereophile report from CES:
The Swiss manufacturer Soulution introduced the $32,000, 75-lb Soulution 511 stereo amplifier at CES 2017. Rated conservatively at 150Wpc into 8 ohms, it delivers 280Wpc into 4 ohms and 560Wpc into 2 ohms. The 511 can be switched to a bridged configuration for power ratings of 560W, 1120W, and 2000W, respectively. In addition, the amplifier is capable of sustaining a current draw of 60 amperes at 36 volts, for an impulse rating of 6000W mono. Its damping factor is listed as 10,000 at 100kHz. Distortion (0.004%) and signal-to-noise ratio (>107dB) measurements at 1kHz are excellent, due in part to the reducing of interfaces and cables used in its construction.
This might be a silly question, but when running two Solution 511s in bridged mode, how do I connect other electronics to them? Does one run as master and the other one as slave as in a Devialet setup or how should I envision that to work?
