Randy Myers
Thank you! That is what I thought: that the devices provided by the ISP are a modem and a switch.
So my question is still: how can can you better performance using “their modem” and your “own router” (or switch) ?
Again looking for technical (i.e., non subjective) proof. Thanks!
The modem always has a single output if it is only a modem (not a one size fits all dual function unit). The modem hooks to the router. Its name tells all, it routes the signal and contains a table of all attached gear down the line, their Mac address, etc. A switch takes a single Ethernet input and splits it up to several Ethernet ports. Four, eight ports; we use multiple 48 port switches at work, but only one router.
Many homes use higher end routers have four or more outputs. In my network box in our home we have the Charter modem that feeds into our Asus router. I had the house pre-wired with cables going to several rooms. I attach the Ethernet cables going to the rooms that I want active to the router.
I have a small switch in our office which feeds our printers, the solar panel connector to feed back to Tesla the status of our panels, and my main computer. There is only one wired network connection in the room (coming off the router). This Ethernet cable hooks into the switch and the other wired devices in the room attach to this switch.
I also have another switch in our bedroom. Again one Ethernet from the router and a TV, NAS, etc., attached to that switch.
The router tracks all 30 some odd devices attached to the network, both wired and wireless. It also contains the network firewall and security settings. It allows all of these devices to be seen across the network. This is how the backup NAS can be in the bedroom (hey, there was a good location for it there) but still be accessible from anywhere in the house. The router does all the heavy lifting, so to speak. Yea, having a top quality after market router is very important to a well performing network.
Anyway, sorry for being so long winded, I just wanted to give the detailed layout for a well fleshed out home network setup.
