Randy Myers
All good questions Randy. Did you get your hearing checked after you bought the AQ Coffee USB cable ?![]()
Yup... By listening to good music
Yup... By listening to good music.
An underlying question does remain though; if we aren’t able to measure what an Ethernet switch does, how are they being designed (much less rated or evaluated for sonics)? Or is it only the audio effects which can’t be measured? Or did I not understand devg and pumacat’s discussion/disagreement about this earlier? And why couldn’t the switch function be built into the server or streamer?
... I've referenced and linked the white paper by John Swenson not once, but twice. It is worthwhile reading it.
White papers are opinion, not fact or evidence. This is at least the second time you have mischaracterized it. I'm not saying you don't have good points, or that you might (or might not) be "right", but it's not appropriate to present promotional material and opinion as fact or evidence.
So far, everything here suggesting that "audiophile" ethernet switches provide an audible advantage over the filtering in a streamer appears to be all subjective, like so much in this hobby. And also like so much in this hobby, subjective opinions can and will differ.
YesHave you read it?
WrongIf you had, you'd see that the white paper is an engineering paper based on data, and is therefore not opinion nor promotional material. Thus, it was not being mischaracterized.
And...its not subjective.
This part is trueJust as f=ma or pv=nRT are not subjective.
You can purchase a standard 3 meter Ethernet cable for $8.04 or you can purchase an Audioquest 3 meter Diamond Ethernet cable for $2899.95.
@Mike, what do you think ? You have all kinds of high/low profile stuff in your arsenal. Does the Audioquest sounds the same as the one from Amazon ?
In my system, the ones from Amazon actually transmits and receives bit-by-bit data accurately with appropriate latency and there is no TCP re-transmission or timeouts or dropouts, neither there are errors in the PHY or MAC statistics on the receiving end. I even tried a full-duplex line rate at 1.44M packets/sec from an Ixia port and they all work out Ok, though there are some drops in the receiver end which is to be expected at these high data rates and the cables aren't the problem. Having said that, for some reason or the other the $8.04 ethernet cable sounds like a $8.04 ethernet cable, until I tried 4 different ones - JCAT, Sablon, Wireworld and SoTM. This is why I moved to fiber which is dirt cheap as the $8.04 ones and saved a ton of money. If someone is interested in JCAT or Sablon, please PM me (I sold the others).
Things get dicey when utility products that have been used for decades by commercial companies get the audiophile makeover. Things start getting gold plated and products that used to be dirt cheap before they received the audiophile makeover now suddenly become as expensive as source components. Then marketing kicks in with a slew of buzz words to describe all of the improvements that have been made to standard utility products that have proven their ability to work in commercial environments under constant use for many years.
actually multiple products have some kind of filtering inside.And why couldn’t the switch function be built into the server or streamer?
We are able to measure the key functionality for a good-sounding Ethernet switch. As for how they are being designed, how the EtherREGN is designed is fully described at UpTone Audio's web page for ER. Have you read it?
As for putting RJ45 connectors, PHYs and flip-flops into a streamer, you could it, but it has to be done correctly. These other manufacturers need to be able to measure high-source leakage impedance current, which is not easy or straightforward. Even the design of the isolation transformer cores is important. Are these manufacturers using grounded center taps for the transformer cores to prevent AC leakage jumping from port to port if here is more than one port? None that I know of.
More to the point, the circuitry between ports on the ‘A’ side decreases phase-noise effects to some degree, but not nearly as much as crossing the ‘A’>’B’ moat. It is the differential isolators used in conjunction with the differential flip-flops that delivers the performance of the EtherREGEN. The differential isolators prevent the data-borne clock signature from getting onto the ground-plane of the PCB, while the differential flip-flops prevent the signature from getting into the flip-flop’s own internal ground network. Are other switch manufacturers doing this? None that I know of.
These other manufacturers need to be able to measure high-source leakage impedance current, and create two isolation zones, as I've described abovet to obtain the benefits ER provides for audio streaming applications; this is not easy or straightforward to do.
...Many reasons but honestly I won't go over it since its extremely difficult to convey anything in this thread![]()
I do think there could be sonic improvements to be had by replacing a SMPS with a linear power supply, but I’m not sure all digital devices will benefit equally. In my setup, I would like to hear the difference with a linear power supply powering my Roon Nucleus+ vice the wall wart it comes with.
Where you not scoffing at me some post back. How dare I insinuate your system leaves performance on the table. And here you are saying gains could be had. So which is it.
It has everything to do with it. Your telling people an off the shelf switch fed with cat 8 terminated on premise (I assume) is just as good as a EtherREGEN with say and AQ cinnamon cable. I believe that is hogwash. So I say your leaving performance on the table. You then imply I have no knowledge of how to make it better. Well I do, as do others who have explained all the small parts and pieces that make up a significantly better whole. Your digital system, especially the steaming portion is not optimized. An optimized steaming system will come close to the performance of stored on rhe hard drive playback. On the hard drive will beat it. But it gets good enough that you stop worrying about where the media came from. Hard drive, NAS or internet. It all sounds darn good. Yes it cost more money. Maybe $2k to $3k to do an entry to mid level package correct. After that you could spend another $3k, but that is going to bring a smaller gain than the first outlay. And for how much money people are spending on DAC and servers. Many ponying up $20k to $30k or more, its foolish to not invest the $3k to set the digital backbone right.Talking about linear power supplies in this thread was an offshoot that started after I mentioned digital dingleberries. This occurred after you decided to butt in with comments about my digital rig. Your comments about the backbone of my digital rig needing to see a digital chiropractor had nothing to do with linear power supplies.
