u-sound
ok, thx.
thought you would need an extreme internet connection for that.
the question: how much resolution do you get with the n-01xd when you stream from a site direct to the dac? no server involved.
How exactly would you stream from a site direct to the DAC without downloading...
In exactly the same way you stream Spotify direct to the DAC without downloading.
thx for all the discussion.
i am new to streamingand close to order the n1xd with the new mutec se120 and a good switch.
the internet speedtest showed 902mbps for download, so the plan is to get a qobuz hi-res membership and stream direct without a storage.
I have been researching the Nagra tube DAC and saw that you bought one sometime back.
Now, you are moving to the Esoteric N-01XD. I am very curious to know how you made this decision, have you compared the two. Does the N-01XD beat the Nagra Tube DAC, which would be quite an accomplishment if true. Since the Esoteric is much cheaper and an SS design.
I am trying to decide between the two, myself.
Thanks,
Bhaskar
hi bhaskar
thx for your question. yes, i had an all nagra system and it sounded very great, organic, rich, thereness. everything finetuned to each other, perfect synergy. the upgrade from hd dac to tube dac with psu was spectactular with good recordings.
the reason to change is that the system i am puzzling together has the intention of an easy modern family system.
streamer, integrated amp, speaker, thats it.
the nagra is a bit complicated to handle for the kids. when you put it on, it takes 2 minutes to warm up. streamer, tube dac and psu means 3 units vs 1 unit (n-01xd).
also, there was a friend who asked multiple times whether i want to sell the nagras. eventually i got weak and sold it about 2 weeks ago.
i have no idea how the two compare. big price difference.
not much help sorry. i really liked the tube dac with the psu. i am pretty sure i will like the esoteric as well.
what is the rest of your electronic if i may ask?
For my money the N-01XD is a no-brainer.
Being an owner of N-01, and being a former owner of many other DAC's, and having heard even more other DAC's than those, the N-01 remains the best I've thus heard. If there wasn't an N-01XD I'd be perfectly content with what I have. For the money, even at MSRP, the N-01XD is a no-brainer.
well, certainly the two, tube dac or n1xd are top units and it might come down to synergy over the last bit of quality.
what i can tell you for sure, the tube dac will be perfect with the 300p. also the internal pre of the tube dac in this combination is at least as good as with an additional classic pre. thats the system my nagra dealer praises a lot. really liked it myself too.
i think it depends on your long term planning about your amp. will you stay with the 300p? if yes, then the tube dac will be hard to beat. if no, the tube dac is still a top dac. but then you might need a pre.
and if streaming is your goal, you will need to wait a couple more monthes for the nagra streamer, and yes, pay for it.
the nagra streamer + tube dac + psu + 3 plattforms.....that is more than double the price of the n1xd.
again, your bill is a bit different, n1xd would mean adding a pre at high level (plus powercorcd, interconnect)
That is very useful information. If the Nagra tube dac will save me from buying the pre, then it's worth it.
Have you heard the combo, the Nagra tube dac straight into the 300p, is that what your Nagra dealer praises or is it with the classic pre that your dealer praises (sorry I didn't get that part) ? I am always wary of DAC direct, have tried so many times and failed.
