MDP
Behavior Moderator (be nice police!)
Magico s1's...for now [emoji48]
I'll be very interested in your comparison.
What speakers will you be driving ?
The Devialet is a great piece but on some speakers it's not a great match. I've tried it on the Salon 2's, as has another member here, and the Hegel H30 was clearly superior.
IMHO when you refer to a system using a Devialet you have to specify all the small details - any of them can spoil the whole system and change your conclusions. I have found that this amplifier is extremely sensitive to all cables (digital signal, speaker and power) and power conditioners. Matching the speaker with the proper cables is not easy, and if I did not have a Transparent Reference MM2 on hand I would have considered that the Devialet was not a good match to the Wilson Audio Sophia 3's I am trying with the 400's since yesterday. None of the other cables from my large collection was able to recreate the fantastic Rigoletto Giulini performance (DG 1980 analog recording) I was listening to a few minutes ago. When paired with the Metronome Calypso transport, the Devialet managed to recreate from the CD some aspects that I had only previously heard from the LP using top equipment, mainly the airiness and feeling of "being there" of the great voices and explosive but always correct dynamics of the orchestra in the more dramatic parts. The Sophia 3 using SAM have now the body and envelopment of big speakers!
If I had the Devialet in my system just for a couple of days my opinion would not have been positive at all. But after two weeks tweaking and burning it I have no doubts it is really a great component. First bad news - in my system the 400's are definitively much better than a single 200. I think I am now wanting to try another extra pair to bi-amp the SoundLabs.![]()
Since the Devialets monitor what's going on at the speaker terminals, IMO, it's a mistake to use network speaker cables like Transparent.
I tried Transparent Reference MM2s and some MIT speaker cables in the same price range with my WA S3s and D400. I returned both.
A transport with an AES/EBU output is important. I have my PS Audio PWT connected to my D400 with an Audience Au24 SE AES/EBU cable. It sounds great with Redbook CDs, and even better with DVD-R discs like the Reference Recordings HRx 176.4 kHz / 24-bit digital masters.
Going back to Raidho C-1.1s - the London Grammar 'Hey You' track is the only track I've ever had any problems with. In two years I've not heard port chuffing or anything negative. I was surprised to hear a problem so brought it up (I probably shouldn't have!).
I've heard a Vitus SIA-025 in place of a Devialet 800 (using the pre-out of the Devialet I seem to recall) and it is superb, but different. A little grainy and not as transparent as the Devialets. Wonderfully musical though. I have to admit I would probably prefer to live with the Devialets as I found them quite neutral whereas the Vitus is a little characterful in comparison. The SIA-025 sure can drive a pair of Sasha 2s though - power is not an issue!
I've tried a few different Transparent speaker cables (though not higher end ones) with Devialet/Raidho and they weren't a good match, but I think this is more a function of Raidho than Devialet. On the other hand the TA Reference XL digital cable is wonderful used between source and Devialet, or between Devialet units, the best I've heard.
(...) On the other hand the TA Reference XL digital cable is wonderful used between source and Devialet, or between Devialet units, the best I've heard.
Rather disappointingly I'm getting some severe cone breakup with that track and my C-1.1s with a Devialet 200. Strangely it's actually worse with SAM enabled than disabled (at the same volume).
Unfortunately yes ... Although it is very expensive, the TA top digital XLR cable operates miracles in my Devialet system. I have been looking for a decent price alternative, but after listening to the Reference XL all others have sounded sounded less "fluid". These comparisons were however carried with the SoundLab A1 PX, not with the Sophia 3.
Are you using a TA Reference XL RCA digital cable between the two mono Devialet's?
Sam is attempting to extend the low frequency response, so not surprising....use a foam plug for the ports, (open cell) and try it again ..
Inexplicable why this keeps coming up..... I think it has already been established several posts ago that this is a unique track & behaviour specific to that piece of music in both Rufus' experience & mine. It appears to be an issue with the modulation inherent in the recording on both vinyl and digital . Perhaps as I've already posted previously , a sympathetic resonance.
I may try port plugs again but I generally find I don't like them. SAM limits the cone movement to 5mm in the case of C-1.1s so that's why I'm a little surprised it's just as bad, if not worse with SAM enabled for me, particularly as someone earlier in the thread I think mentioned SAM cured the problem.
It is only one track and I was really playing it as a test rather than for enjoyment! It really is a non-issue.
Micro,
How is it on the sophia's , I heard them on the Neolith and as you excellent on the ESL 'S ....
