I know it seemed biased. But if you can do an integrated amp, I would consider a Hegel 300.
Tons of power and a sweet sound.
Agreed! Hegels offered tremendous bang for the buck. I did suggest the soon-to-be-released H360 in the previous "Destination" thread, that seemed to have disappeared...
I should have one in about two weeks...
H360 at a glance
New SoundEngine:
A new revision of our patented SoundEngine (adaptive feed forward error correction) that increases
damping factor to above 4000. All this while still maintaining extremely low distortion levels and
up to 60% less power consumption in idle.
New power supply/output stage:
Improved transformer and new output stages allow 50% more current, compared to the H300.
New pre-amp power supply:
Completely separate transformer for pre-amp and DAC results in much lower noise levels.
Improved Balanced input:
Completely new balanced inputs with technology from the Reference P30 pre amp.
Powerful:
The H360 is rated at 2 X 250 watts continuous into 8 ohms, and will be stable into lower impedances.
H360 Streaming
Further improved Apple AirPlay: With the improved master clock we have taken the sound from AirPlay to unheard of quality levels in the H360, maximizing the experience
from streaming services like TIDAL, Beats, etc.
Upnp streaming:
Streaming from a NAS drive to the H360 is significantly improved compared to the H160.
With the new master clock and advanced noise shielding, the H360 is a true streamer.
Works with ”all” apps:
The idea behind Hegel streaming is that you should be able to use the app of choice, and
change as you please. The H360 will work with most all apps on the market.
DSD 64/128:
The USB input now supports native DSD64/128
New D/A-Converter:
Brand new D/A converter with improved masterclock and new AKM chips.
