Mike Lavigne
Mike, have you eliminated all Ethernet from your system, or just after the network switch?
Thanks
on my Taiko Extreme server i have an SFP port. an SFP module plugs into that port and a OS2 fiber optic cable runs upstairs to another SFP module which plugs into a FMC converter which then has a high quality short Ethernet cable to my network gigaswitch (which has a linear power supply). from there to the street it's my LAN with copper ethernet.
then also from my Extreme server i have a USB port. a Gobel LaCord USB cable runs from that into the MSB Pro USB interface. then a fiber optic cable runs from that Pro USB module to a Pro USB input module on my MSB Select II dac.
http://www.msbtechnology.com/accessories/prousb/
so both sides of my Extreme server has fiber optic cable.
note that inside my Extreme server i have 32 terabytes of storage on PCIe drives. i have 17 terabytes of music files at this point.
i run Roon, Tidal and Qobuz along with my files.
