kzhtoo
- Nov 27, 2014
RTFM is always what I do and what I recommend; just make sure when you do with those units, to make sure you not only get the impedance spec confirmed but also that
the device to be connected accepts 10 mHz clock input. Getting forum feedback is great on specs/things needed however IMHO manufacturers' docs are the final authority.
Shunyata Delta and Alpha CLOCK-50 cables...yes, some experience here in testing mode. I found them to be accurate to spec, delivering good imaging, musical truth, etc and
tremendous "bang for the dollar". It won't surprise you that I say if you can squeeze budget and get the Alpha's to do so. If you can only afford the Delta, you still will have
a great performer on your hands and what I would pick over comparable cables I've tried from other brands over the years.
I guess what I read from manuals are what I need. On second thought, I might probably start off with Delta as I need 2 of them. Who knows what I will need more down the road.
