good eye Mike i didnt notice that. do you use your ring camp often? i bought one for my scout once i upgraded to the classic platter. and it just sat around i used it just on a couple occasions. when i got the classic i used it very little too , so i sold it. my merrill came with one and i never use that either except for the occasional warped record. just curious how much you use yours.Beautiful setup Frank!
I have a question. In a couple of your pictures it appears you have the periphery ring located on the platter-ledge (below the LP) and not on top of the LP edge itself? Is this particular record too small in diameter to rest the ring on the LP?
Reason I ask is that I also use the VPI periphery ring on my Classic 2 and have found a number of older LP's that are too small in diameter for the ring to gain "purchase" on the vinyl's outer edge and for those ones I omit the ring altogether.
With most modern records though the periphery ring works very well to further anchor the LP-edge to the platter (in addition to the center clamp) when placed over top of the record.
good eye Mike i didnt notice that. do you use your ring camp often? i bought one for my scout once i upgraded to the classic platter. and it just sat around i used it just on a couple occasions. when i got the classic i used it very little too , so sold it. my merrill came with one and i never use that either except for the occasional warped record. just curious how much you use yours.
cool thanks ,i was just curious as i see alot of people who have tables that came with rings not use them in pics. mine has the dots on it so when i do use it i can use the strobe to check the speed which never needs adjusting. but i hardly ever use it. i may start to use it more. thank youI use mine all the time. I've been told by a couple of TT gurus that the effectiveness is record-dependent and that on some records it is actually a detriment. In the few on/off tests I did when I first got the table, it was always of benefit so I just use it full time.
very interesting maybe i should try to use mine more. ive also hit the side of the ring when dropping my cart onto the record and didnt like the result.lmao!!!I do use mine on most occasions Steve. It really locks the record down to the bare platter when used with the center clamp, especially if there are any small warps to a record. In addition, I think using the ring presents a quieter background too.
As mentioned, I omit it when either the LP is far too small of diameter (some older mono's are this way) and the ring can't be used as it just slips past the record altogether and also when on some records the ring just BARELY BARELY rests on the LP lip (same smaller LP diameter issue but not to the point where the ring slides past) and I'm afraid the ring is going to slip off while spinning and damage my cart/arm.
How stupid i am :blush:, i thought the only function of the ring was to stabilize the platter...
thanks for this precious advice
Frank
Frank
Frank
