Looking forward to your report Paul.
Also I do have to mention that the Pass Labs 350.5 wasn't a good match with these speakers. it was pushing so much details and power to yours ears and I almost fell like bleeding my ears after a half an hour.
He paired with ARC with Pass Labs 350.5 plus Envogue TT and ClearAudio Master solution AMG with two tone arms ( One was Triplanner and can't remember other arm )
This is the biggest red flag for me. It says that something wasn't working for you and maybe these aren't the one. Maybe the amp, maybe the speakers, maybe both. If you're still interested in them you really need to bring your amp with you next time and make sure it isn't the speakers that give you a headache.
Sometimes things just don't work out the way you want them to.
Paul, that's my exact turntable setup except my second arm is a Michell Tecnoarm instead of the Triplanar. The first arm on you left is a Graham Phantom by the way. Did you listen to vinyl when you auditioned the Casta's? If so you may have had many variables that you were not accustomed to compared to your regular listening patterns. Second you seem to want everything the VA's do but in a lusher sound, not sure you can get that with horns. I would suggest you let go of the speaker fetish for the moment and concentrate on the analog front end, I'm sure with time you can dial in your analog front end to make the VA's sing exactly the way you want them. But you need to wet your feet first!
Naturally YMMV
