Almost everything Harman applies to it's speaker design can be traced back to
Toole/Olives work at the NRC
before they got to Harman. Smooth on
and off axis, free of resonances, especially low Q ones. That's why you see similar principles in most of the NRC offshoots like Paradigm, PSB and (now defunct) Mirage, Energy, etc.
But it's not just the NRC inspired manufacturers. Here is an example from Soundstage Networks NRC tests, for the
Magico S5:
Clearly there are smaller manufacturers (myself included) that adhere to those principles....and listeners who like the results.
However, none of this is an indictment of blind/controlled testing, which are the defacto standard of science, whether it be audio/perceptual related science, or the statistics of particle physics.
Perhaps the biggest irony of the Dudley article, is that the
founder of Stereophile, J Gordon Holt, had
this to say about blind tests
Obviously the direction of the magazine has changed since his departure, perhaps to better suit it's readers who seem to loath the defacto standard of perceptual science - blind tests. Which is fine, no one is forcing anyone to change their high end beliefs. No blind test police..yet.
But outside the high end and in the rest of the world, including as I noted, even selecting orchestra performers, blind tests are used.
If you want to remove biases.
If not, enjoy anyway, it's all preferences.
cheers,
AJ
