surrounded by sound
Bob take your time to choose. You want to be happy with what you buy.
Bob, as Mike would have mentioned the more power you have to play with the better position you will be in if you choose to change your speakers & they are not as efficient as the ones you have at the moment. People that buy impulsively without forethought to where they are going with their system usually buy thrice!
@Old Bob,
How loud do you listen ? Distance from your speakers..? And as important, music genre you mostly listen to ..?
hi A. Wayne!
room is only 13 by 13. thus, I sit fairly close to speakers, NOT deafening loud. classical music, as, full orchestras, piano concerto with full orchestra, and SOME eric Clapton,led zeppelin, etc, not super super loud. bob
