Audio Magic Super fuse
I'm assuming you have one already. Have you compared it to any other fuses?
Not yet, but I trust Bart VERY much. I have one or two levels down and it's big improvement. I forget which fuse. I'll find out and report back.
I can accept cables sounding different, but I just don't get how a fuse can?!:bonkers:
Oh ye of little faith. They can even sound different depending on the orientation. I'd choose a fuse upgrade over and expensive ac cord first.
A fuse huh ?? Ida never guessed it would help. I see they are $69 liquid filled fuses. Lol
I will tell you when I opened my amps up on the bottom and realized the fuses were sitting out a little ,'like they got jarred in shipping and I just pressed them all the way in the amp sounded better. If you say it works I'll try it Joe!!
I'm also trying to figure out why I have to buy carbon fiber covers for the Gtx outlets
Seriously? I'll also have to look into this.
I am convinced it makes a difference. I've tried it on several pieces that I've owned. Not just amps but preamps and sources. Basically everything with a fuse. Maybe it makes more sense to think that the last bit of electricity entering the piece goes through the fuse. Some of us don't think twice spending $500-5000 for ac cords so my feeling is that the ac going through that big cord has to squeeze through the little cheap fuse. :)
I'm a believer also. I've tried Isoclean and Hifituning Silver fuses and they both have a a positive effect over the stock fuse.
So what differences do you hear when using these?
Different fuses will introduce different changes. Going from stock to the Isoclean I noticed an increase in clarity and openness to the sound. Moving to the Hifituning was more subtle, but the difference was in greater HF extension.
It sounds odd, but measured a very small difference in resistance between the Isoclean and Hifituning. If I recall it was .1 ohm, and possibly within the error tolerance of my DMM for all I know. Probably electrically insignificant, but it made a sonic difference, which is all I care about.
My experience is similar. Everything just gets a little better in every way. It really is amazing.
Well this just arrived 10 minutes ago. Audio Magic on the left side a little fatter in the middle compared to the stock on right.
Ah, you've been holding out on me John. Let me know what you think.
Fuse is in. I think you're going to like it. It adds a shimmer to music with a little more clarity. Definitely worth a $100 bucks
