Analog to Digital
Has anyone tried to convert their records to digital? I'm curious of the results and findings. It looks like the minimum gear (besides a turntable and phono stage) is something like:
Hilo Reference A/D D/A Converter System
And
Sonic Studio Amarra Hifi High Resolution Music Player and Professional Audio For Mastering Systems
Mike...like anything, its all what you want to put into it...
There are many USB tables now but that's not the way...
One inexpensive and very good way is to go to DAK.COM...get their kit which includes the preamp/mixer and killer software. Cost about $70
I used theirs for a while and it was/is phenominal. Plus it allowed me to use my favorite table with the best sound.
Another way (I also have this) is to get an Echo Gina card/box which allows normal 1/2" or RCA inputs right into a sound card (supplied) ..so you would use your TT and a small pre-into the Echo
Links
DAK LPs To CDs - LPs to MP3s - LPs To Your iPod - Vinyl To CD Perfection Turntable And Interface Mixer
Don't be put off by the cheesy audio commentary..its a great product
The Echo Layla 3G
PCI based audio interface 16 IN 16 OUT | Echo Digital Audio
Here is a clip recorded from a TT to a pre into my Echo Breakout box/PCI card
https://skydrive.live.com/redir?resid=D25B243EF6E53584!133&authkey=!ABxDMm3-YV8zk_U
Takes about 2 minutes to load...
Interesting question for those of us turning to vinyl.
Jeff (jwhite) mentioned on another thread all he needed was some new software to do the conversion. Wonder what setup he has. Hope he chimes in here.
Allen & Mike... I have the Pro-ject USB Phono box (Picture Below). I used it with freeware software program that I can't find on any of my computers now. I did a few albums and was quite impressed with the sound quality on my iPod played through my B&W Zeppelin. I think I printed the software manual. I will try & find it tomorrow.
Just so you guys know...most of the software can be found as freeware..pretty decent too...Its not rocket science...The key here is the best ENTRY into your system...Not the software...
USB is the 3rd best entry...Firewire 2nd...The PCI (Like the Echo Layla) is #1
Make sense ?
Interesting stuff. What's the highest resolution you can encode to with these boxes/software combos?
Make sense ?
Very helpful! Wow dude....you're like the Analog Ninja!
Big +1. Learning a lot from all of your posts, Rob! Thank you!
Going to make this SOOOOO easy for all of you.
1) Go to Amazon and buy this for $49 Amazon.com: ART DJPRE II Phono Preamplifier Dual RCA Type Inputs and Outputs Switchable Low Cut Filter: Musical Instruments
2) Buy 1 RCA (pair) to 3.5 MM plug Stereo (converts L - R to one 3.5 plug)
3) Get the FREE power sound editor here - Free Sound Editor Software for Windows
Okay, I am ASSUMING you have an input jack on your PC sound input (aux input)
Hook your favorite table for this to the ART DJ pre - it has adjustable gain which is great...you will probably set from +2 to +4
Hook the RCA to 3.5 and the 3.5 to the AUX input on your PC
Make sure your PC has the AUX input turned on (system volume/recording control)
Open Power Sound editor
Start turntable, lower needle, hit record on the software....You are done !!! Total cost about $55 and great recording (because you are using your sound cart so the bitrate and speed is at its best)
That work ?
Quick note on PCI vs USB
USB, PCI and Firewire are just pipes going into the PC.
Only difference is PCI is a bigger pipe and could support many more channels,
usb2 tops off at about 16 (Firewire400 about 100, PCI several hundred).
USB 2.0 runs at 400Mbps (mega BITS) peer second
PCI runs at 133MBps (mega BYTES per second)
1 BYTE is 8 Bits so to compare, divide the 400 by 8 and you get 50MBps for USB or slightly higher than 1/3 of the PCI rate...that's why I always suggest PCI (sound card input) vs USB
I'm just finishing up doing a bunch of records. I decided to spend the same amount of money as going direct to PC and make life easier for myself. I use a Tascam CDRW900SL to record to CDRW, rip it into the PC in wav, edit and make nice in Audacity then burn to CDR. I also take it further and do the appropriate artwork labels and such, but I'm just OCD/Anal about that. Those are just the basics, my process is more detailed that that from the start.
