From what I have read elsewhere written by recording engineers, recording to tape lets you push things a bit and record a wee bit hot. Tape apparently will compress things in a very natural way, but soft still stays soft relative to loud.
For digital you have to limit your top end so that it never exceeds that 0 point, otherwise it will distort horribly. And modern day recordings will generally overcompress things so even the soft sounds have a higher dynamic than they should relative to the loud sounds, making everything loud and flattening the dynamic range.
From this I infer that in general digital sounds loud and can appear dynamic in something like a car, but generally everything is loud. But from a relative perspective vinyl has more dynamic range, going from loud to soft across the spectrum.
yes and thank god for the high resolution down loads like 24bit/96khz Studio Masters.
I believe that both CDs and LPs can be equally adept at dynamics.
But digital does have the advantage. ...When digitally well done.
Eric, I think digital has a dynamic range of 100dBs or so (+/-). ...CD (16/44) is 96dB.
Analog I don't think is that high. ...Few dBs below.
But it don't matter because analog R2R tapes and LPs sound so much better. ...Most generally.
I think it has to do with "nostalgia".
We don't get that with digital.
Wait until digital downloads are the norm, then the generation that grew up with CDs will be nostalgic about them like we are with vinyl.
Of course I don't think it's "just" nostalgia. I think vinyl sounds better than digital...
'one of the truest statements I've ever read on any audiophile site. Nostalgia trumps facts all the time these days.![]()
So in terms of the physical medium's capability, Bob is right. CD (and certainly hi-rez digital) is capable of delivering a wider dynamic range than LP or tape ...
... but in terms of the medium's pure ability to deliver a wider dynamic range, digital (CD resolution on up) beats vinyl and tape.
I disagree.
Downloads have no value at all. They are not physical media and many downloads are free.
It may help to think of it like this; CD's and Vinyl are physical. Physical = collectable. Collectable = potentially valuable.
So in terms of the physical medium's capability, Bob is right. CD (and certainly hi-rez digital) is capable of delivering a wider dynamic range than LP or tape but the reality is most digital recordings are mastered "hot" as BobM mentioned where the mastering engineers boosts the dBs across the entire song because artists and music studios want their songs/albums to sound loud because most people listen to the material on car radios, iPods, etc...(i.e., crappy play-back gear) and when you boost everything it makes it sound louder/clearer on inferior playback gear. This is known as the "Loudness" wars and much has been written about it. Generally speaking, LPs are marketed to a more discerning consumer and are generally mastered less "hot," meaning the mastering engineers retain more of the dynamic swings (soft to loud to soft etc...) because LP buyers are generally (again not always) more likely to have mid-fi to audiophile gear that is able to clearly showcase those dynamic swings/changes in a song, which by the way is one of the key things that makes music so enjoyable - that emotional roller coaster that a shift in dynamic can take you as part of the song's message.
If you google "loudness wars" and "compression" you will get a ton of hits on this. And of course there are a ton of differing opinions about this, even among mastering engineers but in terms of the medium's pure ability to deliver a wider dynamic range, digital (CD resolution on up) beats vinyl and tape.
