Tubes testers on my radar ... Need recommendations ....
joeinid
Super Moderator
NY
Welcome!
Welcome to Amplitrex Audio Products! We are the manufacturer and exclusive distributor of The AT1000 Electron Tube Test System.
AT1000 Features:
  • Tests hundreds of popular vacuum tubes
  • Regulated, overcurrent-protected power supplies
  • Easy to use, just select tube and start the test
  • Tests for emission, transconductance, and gas/leakage
  • Optionally tests Pentodes and Tetrodes in Triode Mode
  • Selectable Fixed or Auto Bias modes
  • Selectable Timed or Manual Test modes
  • Detects "run-away" power tubes
  • Built-in Headphone amplifier
  • Rugged, industrial-quality construction
  • Connect to PC computer for additional features
  • Free TubeTest© Software
  • One-Year Warranty
  • And more!
or
Maxi Test : Digital Tube Tester, Vacuum Tube Testing, Power Tube, Dual Triode, Maxi-Matcher, Maximatcher
[TD="colspan: 6"]
[/TD]
[TD="width: 163, colspan: 2"]
[/TD]
[TD="width: 363, colspan: 6"]
[/TD]
[TD="width: 82"] [/TD]
[TD="width: 80, colspan: 2"] [/TD]
[TD="width: 37"]
[/TD]
[/TD]
[TD="width: 114, colspan: 2"]
[/TD]
[TD="width: 268, colspan: 3"]
[/TD]
[TD="width: 697, colspan: 9"]
[/TD]
[TD="width: 114, bgcolor: #f0f0f0, colspan: 2"][/TD]
[TD="width: 268, bgcolor: #f0f0f0, colspan: 3"]
Introducing the new state of the art of tube measurement - the MaxiPreamp II. Improving on the already classic MaxiPreamp, the new version is packed with upgrades and a clean new look. As always, the Pre is there to help you make the best possible choices for your tube equipment, producing fast, highly accurate and easy to understand results.
learn more... Click here to see our other testers.
[/TD]
[TD="width: 1079, colspan: 14"]
Our Maxi Preamp has become an indispensable piece in our shop. Whether it is checking incoming tubes or tubes that have been pulled from a customer's amp, the Maxi-Preamp quickly takes the mysteries away. Easy to use, fast and accurate. I do not know how we have gotten along all these years without one! Thanks for a great piece of equipment!
Art Jacobson
A & M Amp Repair
Rock Rapids, Iowa​
[/TD]
[TD="width: 1079, colspan: 14"][/TD]
[TD="width: 39"][/TD]
[TD="width: 232, colspan: 2"] MaxiBurn
Ultimate Power Tube Burn-in Station[/TD]
[TD="width: 11"][/TD]
[TD="width: 232, colspan: 2"] MaxiMatcher
Digital Power Tube Matching Station[/TD]
[TD="width: 13"][/TD]
[TD="width: 232, colspan: 2"] MaxiPreamp
Ultra Precise Digital Preamp Tester[/TD]
[TD="width: 12"]
[/TD]
[TD="width: 232, colspan: 3"] Adapters
High Quality Adapters[/TD]
[TD="width: 37"][/TD]
[TD="width: 232, colspan: 2"] [/TD]
[TD="width: 12"]
[/TD]
[TD="width: 232, colspan: 3"] [/TD]
[TD="width: 232, colspan: 2"] • Stabilize tubes before matching for more accurate results
• Improve reliability by eliminating
early failures
• Visual indicator on each tube to sort out failed tubes
learn more...
[/TD]
[TD="width: 232, colspan: 2"] • Instantly identify weak or damaged
power tubes
• Accurately measure a tubes
amplification quality
• Precision-match tubes for plate current and transconductance
learn more...
[/TD]
[TD="width: 232, colspan: 2"] • Measure preamp tubes for Gain, Transconductance and Noise
• Test any common dual or single
preamp triode
• Audition tubes with dual-RCA Direct Audio Output
learn more...
[/TD]
[TD="width: 12"]
[/TD]
[TD="width: 232, colspan: 3"] • Adapt non-standard pinouts to
the testers[/TD]
You should get it and rent it out. Lol. $50 plus shipping to test all your tubes would be a great deal. You just gotta make sure they send it back lol!!!
Fantastic thread! I was thinking about this as well.
It sure would be good if I could do some basic testing as well as even a bit of "matching"
In all honesty, I don't have a clue.
I do know from talking to tube people over the years that most tube testers only test a fraction of the tube and only the more extensive (expensive I'm sure) do an adequate job to match tubes etc.
Some of the models can do that.
The Amplitrex looks more complicated - so get that one. :)
Ha! :P
I don't think my preamp tubes will be a problem. I am more concerned about the power tubes taking the amp but there is a big fuse on my ART amps that should protect everything.
tubeaudiostore_2256_11816
[TABLE="width: 501"]
[TR]
[TD]
tubeaudiostore_2245_647920
[FONT=arial, helvetica][SIZE=+1]WE GLADLY ACCEPT MASTERCARD AND VISA WITHIN THE UNITED STATES. FOR ORDERS OUTSIDE THE US, PLEASE USE PAYPAL: [email protected]
Welcome to tubeaudiostore.com, the home of RAM Labs tubes and Music Reference audio equipment. Founded in 1983 by world reknowned equipment designer, Roger A. Modjeski, RAM Labs has made its mission to bring you the highest quality, most reliable tubes available. For example, our Super Low Noise preamp tubes are within 1dB of the theoretical noise limit for that tube.
The world of tubes today can be confusing, even frustrating when it comes to selecting the right tubes for your equipment. It's often difficult to tell what really matters and what doesn't. At RAM Labs, tubes are our life's work. We know what matters so that you can be assured that the tubes you purchase will meet our specifications and your needs.
Our experience with designing tube audio equipment and visiting tube factories around the world means that we know exactly how a tube will perform, in circuit, and that's what really matters. The information we have provided on this site is based on these years of experience and we have sought to guide you in making an intelligent and informed buying decision that is right for you and your equipment.
Every tube we sell is selected, tested and graded using a proprietary computer testing system developed by Mr. Modjeski so that even our Standard Grade tubes will outperform most tubes on the market. And all tubes come with a 90 day satisfaction guarantee.
In addition to tubes we are now offering select Music Reference components and accessories online. We have available reference quality interconnects as well as some very affordable and exciting passive preamplifier kits.
For more information on Music Reference components visit the Music Reference Site or read Stereophile Magazine's Class A review of the RM-200 Power Amplifier. Call us or email for the nearest dealer.
All tubes carry a 90 day warranty provided they are returned in the original box and not subjected to abuse. Components carry a 1 year warranty for parts and labor.[/SIZE][/FONT][/TD]
[/TR]
[/TABLE]
I remember when I was about 12 years old my mother used to give me a bag of tubes from our tv to take to the drugstore where they had a tube tester and see if they all worked.....seems like a very long time ago:) Oh wait, it was a very long time ago....50 years!
I used to go with my Dad to the local drugstore and they had a tube tester as you walk in. I'd play with all the knobs. Fun times.
I've tried many tube testers. Currently I have Amplitrex, Maxi-Matcher, Hickok 539, Western Electric KS-15874. All have strengths and weaknesses. Amplitrex is the most expensive, but most precise - however, it can't test a lot of tubes. Maxi-Matcher is good for quick matching of power tubes, but transconductance reading is not very precise. Hickok is great and can test 1000 or so tubes - having a spec for a tube, it can test anything. Western Electric is super fast and very precise - this one is considered to be the best vintage tester since it uses different circuitry for different types of tubes. Love them all, have to have them all, but I only could have one and needed to test only audio and power tubes and money was not an object... I would go with Amplitrex; otherwise, I would go with Western Electric KS-15874 (getting cards is PITA) or Hickok 539C. I tried Hickok 600, 6000 and TV-7, but wasn't impressed with them and let them go.
