TIDAL stuttering issues
Peter,
I don't think it's a Tidal's problem as I have no problem with Tidal when using my smart phone. I'm 99% sure it's the high ping times associated with my Internet provider, AT&T UVerse.
Brian ...
Brian,
I've increased the buffer size for Tidal in the firmware and sent to you in PM, see if it helps with a less than ideal internet connection.
Thanks Peter, I'll try the firmware revision tonight when I return home from work and will let you know. The UVerse ping issue is so bad that one of my TVs pixelates all the time. The TV is on the same gigabit switch as the Lumin. I'm scheduling an AT&T tech to come to the house.
Brian ...
