Interesting. I needed a new ss amp when I decided to move away from SETs a few years ago. I bought or borrowed a dozen amps including the ML 5805 (although I'd have bought the 5802 if I'd taken the ML route). plus a number of A, AB and D contenders. Some were surprisingly and disappointingly bad, but the ML was not in that group. In the end I went for a Class D - the Purifi Eigentakt-based NAD M33 (M23 is the power amp only version). If offered all the quality of the other amps but with far more features. The best AB in my system was the GamuT D200 (now discontinued) but the ML was close on its heels!I had 2 Class D amps recently. Both Marantz Integrated amps. The PM-KI Ruby which I loved and the PM-10 which costs double of what the Ruby does. The PM-10 did not move the needle for me. The Ruby had great tone, bass and a glorious midrange but it was lacking the detail that I was used to, so I sold it and bought the PM-10 which sounded very good at times and just meh other times. The center image was also very diffuse. I returned it and bought a Mark Levinson 5805 Integrated which is an AB amp. It is just fabulous and sounds better in most respects compared to my BAT-Pass combo. The DAC in the ML is spectacular. The Phono preamp is supposed to be awesome but I have not tried it as I am using a Gold Note PH-10 phono preamp.
On Tuesday (6JAN26) I take delivery of AGD Audion mono blocks. It is actually with a bit of trepidation. It will be interesting to hear if they blow the custom shop Class D Audio GanFET mono blocks out of the water. For the Class D’s are no slouches.Very happy owner of AGD Duets powering DeVore Super Nines! I looked at other options but what swayed me was the small size (don't have enough room for most mono blocks) and that they are upgradeable by the owner. GaN FET is relatively new, so the technology will evolve. I have owned them for over a year now and they are great sounding, plus more efficient than other classes of amps. Dare I say.. my "final amps"?
Hope they work out for you. Please keep up updated on your thoughts.On Tuesday (6JAN26) I take delivery of AGD Audion mono blocks. It is actually with a bit of trepidation. It will be interesting to hear if they blow the custom shop Class D Audio GanFET mono blocks out of the water. For the Class D’s are no slouches.
6922's have good news and bad news.I just put a different set of tubes in the preamp. NOS 6922 JAN Phillips.
The AGD Audion will have a steep hill to climb.
I’m really naive about tubes the change for the better in terms of system resolution has left me with my mouth agape.
Time will tell.
In my case ignorance is bliss. Plus I’m a cheap bastard and simply will not fork over some of the $$$ being demanded by the various tube purveyors. Thus the JAN Phillips. I do have some Japanese Matsushita tubes coming from the fellow you recommended to also try.6922's have good news and bad news.
Good news: there are a wide variety of vintage tubes to try.
Bad news - it's a very popular tube so prices for them have climbed dramatically lately for decent pairs.
My suggestion is if you find a pair you like - make sure you:
1) confirm they are manufactured by the company on the label. Many tubes are not made by the brand name on the box or tube label as brands often made tubes for each other and would simply put anothers label on it;
2) Confirm the YEAR of mfg as the same tube, same company, but different years can sound VERY different from each other.
So for instance it's not enough to simply say "I like the sound of the RCA 6922". It may not actually be an RCA and depending on when it was made will make a huge difference. I personally feel usually the older the tube the better.
The JAN Phillips is probably a legit Phillips and is a first step between current production and real vintage tubes.
My suggestion: vintage tubes require SERIOUS dedication. If you are happy with the JAN Phillips, sometimes ignorance is bliss and think twice before going down the rat hole any further.![]()
The Japanese are usually very high quality tubes and get you a much more expensive sound at a cheaper price. I think you'll like them. Just remember new tubes need about 25 hours of initial use to sound their best.In my case ignorance is bliss. Plus I’m a cheap bastard and simply will not fork over some of the $$$ being demanded by the various tube purveyors. Thus the JAN Phillips. I do have some Japanese Matsushita tubes coming from the fellow you recommended to also try.
I get so irritated with reviewers that seem to push Class D so hard yet when you see their reference system, where's the Class D. Future Audiophile is really guilty of this.
Easy twenty hours of playing time. The definition is spot on. FAST! Musical. Excellent sound stage. Albeit quite a bit of speaker repositioning occurred.Hope they work out for you. Please keep up updated on your thoughts.
