Starke Sound Beta5 review
_theaudiofile
G’day!
Unless you’ve been living under a rock, you’ve probably heard the rumours of a new audio messiah. The way the audio community (and maybe even your grandparents) are hyping up the Starke Sound Beta 5 bookshelf speakers, you'd think they turn water into wine. Being the audio nerd that I am, I reached out to Starke Sound directly to get my ears on these and see what all the hype is about.
Full disclosure: I am not being paid a single cent for this review. The mutual agreement was simple: I share my honest, unfiltered thoughts. They haven't interfered, haven't asked for a sneak peek and have had absolutely zilch influence. That earns respect in my book.
TL;DR - Overall Rating: 4.8/5
The bottom line: The Starke Sound Beta 5 speakers deliver a killer price-to-performance ratio for $499 (USD). They are built like tanks and offer the refinement and expansive 3D soundstage of speakers costing three times as much. They more than hold their own as a highly engaging music listening experience straight out of the box, but as you’ll read below, there are a few specific ways to really unlock their full potential.
Unboxing
First impressions matter, and Starke Sound knows this. I won't bore you with every little detail and will let the pictures do the talking. No cheap, crumbly polystyrene here; they are secured in precision-cut, high-density foam. The cabinets come wrapped in soft cloth bags; I'm giving that a HD for Hot damn!.
As for the Stand 3S... the "S" might stand for ssssexxyy! 'Nuff said. They are the sexiest stands I own. Granted, they're the only stands I own, but still. I definitely tried to flex them in the pictures because they just present so well.
Build Quality
Out of the box, the first thing that smacks you is the density of these cabinets. Each speaker weighs in at a hefty 6.8 kg. You might be able to use them for bicep curls. Starke Sound dumped their budget where it counts: the engineering and construction. The front baffle is made of polycarbonate and is a beefy 32 mm thick, while the rear wall is 19 mm thick. Internally, my research tells me that it's heavily braced and lined with damping material. Give it the ol' knock test and it’s as dead as a rock, meaning absolutely zero unwanted resonances.
The finish on the veneer is amazing to touch. The Beta 5 sports a 133 mm carbon fiber sandwich cone mid-bass driver with a heavy-duty cast basket; something you almost never see at this price point. Both the 29 mm soft dome tweeter and the mid-bass motor assemblies use copper shorting rings (Faraday rings) to reduce distortion. Around the back, you’ll find a beautifully machined billet aluminium terminal plate with high-quality binding posts. I'm a total sucker for details like this, it makes the audio nerd in me very happy.
Here is my first critique, though. While I love the overall design and how easily it blends into a modern living space, we need to talk about the grille. It features a figure-8 shape structure on the inside. I highly recommend popping it off. Not just because the drivers look great exposed, but because taking the grille off lets the sound completely open up. Any obstruction is the enemy of good audio, and removing it makes a noticeable difference.
What you’re here for:
I hooked these up to my Denon X2800H receiver and tested them out in both a small room and a medium room setup.
Given that this is a 133 mm driver, I kept my expectations in check, I wasn't expecting to get noise complaints from the neighbours anytime soon. But the bass extension on the Beta 5 took me by surprise. They dig down to a rated 45 Hz, and you absolutely feel it. The low-end is punchy, tight and brilliantly controlled. Compared to my SVS Prime Bookshelf speakers, I dare say the Beta 5 delivers more clarity and transparency
Music Experience:
If you appreciate a neutral, studio-reference style of midrange, you are going to be pleasantly surprised. Vocals have beautiful weight and texture to them. Instead of shoving the mids in your face, instruments and voices mix together beautifully. The 29 mm silk dome tweeter is the real MVP here. It delivers a ridiculous amount of air, micro-detail, and clarity, creating a wildly expansive soundstage in both width and depth. I close my eyes and the speakers completely disappear; sonically, of course
I threw different genres at them; Fleetwood Mac, Whitney Houston, Marvin Gaye, Bruno Mars, you name it. When playing Fleetwood Mac’s "The Chain," you can literally hear the subtle scrape of fingers sliding across the acoustic guitar strings, and when that iconic bassline drops, it sits entirely on its own without muddying up the vocal harmonies. Cue up Whitney Houston, and her voice has this incredible, commanding weight to it. You get the actual resonance of the singer's chest, not just sound pushed through a cone.
It does an amazing job across the board. Using standard 12 AWG OFC Monoprice speaker cables, I'd give the music experience a 4.7/5. But swapping in my custom Canare 4S11 cables? It brought so much clarity and depth, lifting the music experience to a 4.9/5, which is basically as close to perfection as possible for this tier. (For the cable myth-busters out there reading this, I know this is controversial, so please lower your pitchforks and let's just respect each other's views!).
Movie Experience:
This is the only slightly negative thing I can say about this speaker. While it is near perfection for music, the cinematic experience is a little lacking out of the box, earning a 4.2/5. Don't get me wrong, the imaging is fantastic. If you throw on Top Gun: Maverick, the dialogue is dead-center and crisp, and as the jets scream across the screen, the spatial panning is pinpoint accurate thanks to that highly revealing tweeter. You might actually duck when Tom Cruise buzzes the tower.
But when those afterburners kick in, or when that massive, room-shaking synth drops in the opening scene of Blade Runner 2049, you hit the physical limitations of a 5.25-inch driver. It lacks that deep, room-pressurizing, visceral rumble that makes home theatre so ridiculously fun. I also threw on The Batman, specifically the rainy Batmobile chase scene. The Beta 5s perfectly captured the sharp screeching of the tyres, the shattering glass, and the raw growl of the engine, but you don't actually feel that engine idling in your chest.
Usually, I rely on my SVS PB2000 subwoofer to fill out the bottom end, and if you're using these for movies, you'll definitely want a capable sub to handle those deep, subsonic frequencies. Once you cross them over to a dedicated subwoofer and let it do the heavy lifting, though? Absolute cinema.
Stats for the nerds
I'm not getting paid to be their technical writer. If you want the deep-dive specs, refer to their website.
Frequency Response: 45 Hz – 23 kHz
Impedance: 4 Ohms
Drivers: 1.15-inch (29 mm) soft dome tweeter and a 5.25-inch (133 mm) carbon fibre mid-bass.
The Baffle: 32 mm thick Polycarbonate
Weight: 6.8 kg each
Verdict
Starke Sound nailed the aesthetics and construction here. For my setup, the Aoki Flaxen Grey finish paired with the grey Stand 3S is a match made in heaven. It easily blends into the living space. I'm also a big fan of the discreet logo. Combine those clean looks with the tank-like build, the value is indisputable. Sonically, that expansive 3D soundstage and highly detailed tweeter make these an absolute joy when I just want to sit back for some critical listening.
But nothing is perfect, because these bad boys are rear-ported, you can’t just shove them right up against a wall, dust your hands off and call it a day. I found they really shine with a bit of real estate to breathe and do their thing. Also, because that tweeter is so incredibly revealing, the highs can lean a tiny bit bright if you decide to absolutely blast them past the 95 dB mark. So keep the volume at a reasonable "I'd like to keep my hearing into my retirement" level.
We also need to talk about my biggest gripe: the grille. It features a thick, figure-8 shape structure on the inside. Any obstruction is the enemy of good audio, and leaving these grilles on noticeably holds the speakers back. I suggest Starke Sound consider a fully perforated grille for their successor releases so the sound can remain transparent without any blockage. For now, do yourself a favour and just leave the grilles in the box.
At $499 (USD), I don't think the Starke Sound Beta 5 is just a good speaker; these bad boys are absolutely amazing. Looking at the cast baskets, the Faraday rings, that crazy thick baffle, and the beautifully machined billet aluminium plates, it really feels like Starke Sound blew their entire budget on raw engineering and forgot to hire a marketing department. If you're building a dedicated two-channel setup or upgrading your home theatre fronts and want high-end transparency, dynamic punch, and exceptional build quality without having to take out a second mortgage, the Beta 5 should to be at the top of your list.
Build Quality: 5/5
Sound Quality: 4.5/5
Value: 5/5
