chops
Chops and Octopus
Whilst I certainly agree many of your points, I believe that a carefully set up and DSP-tuned full-range pair of speakers is both more cost-effective and less aesthetically jarring than smaller speakers plus a couple of subs.
"Audiophiles would prefer a speaker that doesn't need subs for sublime sound".
Not wanting to promote Avantgarde speakers, but they do offer ample bass from twin 12" drivers per side and include a DSP that allow you to flatten out the peaks and nulls (up to about 150Hz) to suit your room's acoustic difficulties without separate subs. Third party DSP's are designed to do much the same, though my own experience with the 4 systems I've tried at home is not convincing. Yes they flatten out these peaks and nulls, but they also tend to take away a little of the music's lifelike sound and reduce its excitement factor. I've not yet spent time with AG’s DSP because I don't have measuring equipment, but I will when I'm totally happy with their placement. Meanwhile I usually switch off Dirac Live for the reasons given despite the much flatter bass response.
I’m not trying to be confrontational but just to suggest there’s more than one way to skin a cat (sorry Chops) and in this day and age - perhaps a more sophisticated and less costly way than adding more speaker boxes to your listening room. Peter
PS Although we are slightly off-topic, I suspect the OP may be interested in this discussion as it could influence his speaker choice.
Again, it does not matter what the loudspeaker is or its capabilities, and DSP simply can not rectify nulls in a room.
I'm going to drop the whole loudspeaker part of this post because I've already covered that to great detail.
However, DSP is not the answer either. It can not and will not solve physical issues with the room. The only thing DSP can do is correct for peaks in the room, that's it. No matter how much DSP, EQ, amplifier power you throw at it, these things will NOT solve the issues of nulls in a room. The only things that can be done to solve nulls is loudspeaker placement, subwoofer placement, and listening position. Not much else is going to solve null issues for you, no matter how much tech you throw at it.
