I need to finally replace an old and beat SKIL cordless drill / driver with a decent unit.
Seems the standard now is 18v Lithium Ion technology which is fine as it provides ample power and lighter weight.
My needs are 100% general use. I don't need a specialty combo pack that might include a hammer drill or impact driver or recip saw. 3/8" or 1/2" chuck is fine. All the current models / brands appear to have clutch drive adjustment and two speeds which are needed.
I prefer Makita or Milwaukee brand as I've used them over the years and they just feel right but am open to other suggestions too.
What do you recommend either from discontinued models that are "must have" and might be found NOS or from current model offerings?
Thanks.
Thanks.
