Shunyata Denali 6000S + two Denali 2000T's + Sigma PC's
ok so if someone has a standard 15amp outlet then they should not use a denali with it? I am a little confused now
All Denalis have a 20 amp "continuous" current rating. This is a maximum rating. Of course you can connect them to any circuit with a lower rating.
We use an IEC C19 inlet because it is rated at 20A @ 125V. This enables those that have 20A dedicated lines installed to use the full potential of the line.
What you can't do is use a standard power cord with a C15 or C13 connector because it won't physically fit into a C19 inlet. This is why some people are asking about adapters.
Does that help?
ok thats what i thought, last question. if you use a 15a sigma to the denali from the wall does it make any sense to use a 20a from the denali to the components or the amp? my assumption is that both the 15 and 20 use the same gauge internally and that the connector plug is the only difference.
The SIGMA Analog & Digital models use 8 gauge wiring internally while the SIGMA-HC has 6 gauge. The internal gauge of the wire is the same regardless of the connectors used.
Caelin, thanks for all the useful input on the Denali. I have a question about the HC zone with QR/BB of the 6 outlet models. If one needed only to use one of these outlets for a stereo amp, but needed 5 other outlets, is there any benefit or negative affect by using this outlet? If so, which type of equipment would be benefitted or hindered the most using it...DAC, Preamp, phono stage etc. Thanks
Hello,
There would be no compromise. We have run stereo Constellation and Luxman amps through the filtered outlets at shows and in homes that have multiple amps (5 channel)--with no audible drawback. Also, there are systems that have one stereo amp and 5 line-level components and sources where a DAC or Analog pre-amp goes through the high-current outlets by necessity.
Denali technology has no hard rules, in the same way that a Sigma Digital may differ from a Sigma Analog. Yes, there are small differences but in the end each model of power cord and each outlet on a Denali is a Swiss Army Knife of sorts in terms of application. Denali models maximize noise isolation and through-put of instantaneous current (DTCD).
To answer your question, I would run the stereo amp through one-half of the HC (high-current) duplex and the main pre-amp through the other half for best performance. If you are willing to experiment, you could try the phono stage as well if that is your main source but in general, the main pre-amp is likely best in that other HC spot.
I don't wish to be ambiguous, but I have tested these units every way imaginable, as have our close industry partners, reviewers, studios and medical. I believe you would have to go out of your way to make an error in application, even if you misapplied a Sigma Digital for a Sigma Analog, or plugged an amp into a filtered Denali outlet. The differences are there, but subtle. I would be happy to go over your specific system application if you care to call or e-mail. All of our products are essentially universal in performance but possess small specialities in terms of filtering, DTCD and parts-engineering. There are no big mistakes that can be made, only refinements toward an ideal.
Please let me know if I can be of any further help!
Best regards,
Grant
The HC zone was designed for very high current devices and those that may not require higher levels of noise isolation - like amplifiers. Zones 1 & 2 have very high levels of isolation which means they are ideal for noisy components: DACs, transports, turntable motors, etc. Preamps with integrated digital devices usually work best in the Z1, Z2 outlets also.
Simple preamps probably sound best in the HC outlet if it is not taken by another component.
FWIW the Z1 and Z2 are NOT low current outlets. They are rated at a full 15 amps of current unlike many competitors where the highly filtered outlets are only rated at 5 amps of current. Many people are using the Z1, Z2 outlets with certain amplifiers saying that they sound best through these outlets. We have general guidelines but a bit of experimentation with your own equipment is helpful.
Grant/Caelin - thanks for the responses. I plugged my Studer R2R and Doshi Tape Preamp into the Denali 6000 this weekend. Helped tremendously with noise floor and so much more. I found the Tape Preamp sounded best in one of the spare HC inputs on my 6000. I'm using two 2000's dedicated for my amps. I've NEVER had a lower noise floor than I do now. The Denali passes the 300b SET/horn speaker test with flying colors. [emoji573][emoji322][emoji324][emoji573][emoji322][emoji324]
Hong Kong:
Any Denali owners have additional feedback? Notice any changes after a week? Two?
My Denali and Sigma PC's are singing sweetly! LOVE how quiet the Denali has made my SET/horn system.
Great question Mike. No, not really. To me the beauty of the Denali is that it ships essentially burned in already and sounds great from Day 1.
Sounds/performs as wonderful today as it did Day 1...
I am waiting for someone :rolleyes: that purchased the S model to sell it to me really cheap so he can get that Tower unit that he wanted all along! ..hmmmmmmmm......hopefully within driving distance.......of St Petersburg.....lol.
Ha! Once you hear it in your system, there will be no going back.
Same for me!
The audio fairy visited today. I've been a good boy apparently!!
Thanks Mike for the help with the decision and super quick turnaround! Top notch service again!!
I love how Shunyata also paid attention to form and function. The fact the tower unit comes with a built in isolation base and internal isolation. The fact it stands upright so to save horizontal floor space and easier cable management. The fact it has the doohickeys that hold the heavy plugs from falling out (that to me was a "thank you for addressing my current biggest pet peeve with three prong connectors"). Love that it is passive. Love that it does not limit current. I assume 100 percent class A amps will work well with the QR/BB?
