mep
- Dec 4, 2013
I treat them all the same. Caveat Emptor!
They are indistinguishable.
I don't need a disclaimer and just treat all posts / reviews the same. If read enough from an individual, you know the bias and then consume accordingly.They are indistinguishable.
I would love to try the Luxman C900u preamp with my JR 625 S2 amplifier.
I agree with your post and you know I respect your opinion. I would like to hear the C900u with my 625 S2 in my system. Usually, but not always there isn't a night and day difference between components that are considered on the same level. Will the C900u be a real game changer in my system or a lateral move? My next move for now is going from dual REL Carbon Limited subs to a REL no. 25.As you know I tried this combo with outstanding effect.
Both excellent.
HelloAs a former owner of the Rowland 625 (pre-S2) and currently running the Luxman M-900u I don't think there's necessarily a decisive winner in this comparison. I've also heard the 625 S2 extensively which is a significant evolutionary advance over the earlier version. Both amps are exceptional products and I think a preference is likely to come down to which is a better match to a given set of speakers as well as system synergy. I used to run Magnepan 3.7i and with them I'd give the nod to the Rowland which had greater dynamic swings and an overall effortlessness that the Luxman lacked. However I then changed to Dynaudio Contour 60 speakers and my preference shifted to the Luxman with amazing texture, harmonic integrity and overall musicality. Once you get to this level of gear I find that system matching and personal preference play a major role in determining which would be considered best.
Hello... The answer to your question is an enthusiastic YES regarding the Magnepan 3.7i since I had that exact combo and it is exceptional! Effortless dynamics, smooth, musical, and spacious! Regarding the 20.7 I can't definitively say since I've never had them or heard them driven by the 625, but my guess would be that they'd be similarly well matched. Hope that helps.Hello
I have a Corus and model 625 (first version), do you think I can drive magnepan 3.7i or 20.7i with ?
Thanks
Thank you.Hello... The answer to your question is an enthusiastic YES regarding the Magnepan 3.7i since I had that exact combo and it is exceptional! Effortless dynamics, smooth, musical, and spacious! Regarding the 20.7 I can't definitively say since I've never had them or heard them driven by the 625, but my guess would be that they'd be similarly well matched. Hope that helps.
Thanks again.Hello... The answer to your question is an enthusiastic YES regarding the Magnepan 3.7i since I had that exact combo and it is exceptional! Effortless dynamics, smooth, musical, and spacious! Regarding the 20.7 I can't definitively say since I've never had them or heard them driven by the 625, but my guess would be that they'd be similarly well matched. Hope that helps.
Congrats on your newly ordered Magnepans! The true ribbon tweeter of the 3.7i and 20.7i is vastly superior to the quasi-ribbon used in the 1.7i, they exhibit an effortless and airy high frequency response that is exceptional. Enjoy them in the best of health!Thanks again.
I have listening the magnepan 1.7i.
They don't have the 3.7i.
I pass an order.
I must wait two months...
Envoyé de mon HTC 10 en utilisant Tapatalk
