Now that I have had the Stage 2 for a few days I am starting to really settle in with it. Last night I was playing some very good recordings that I have listened to many times and I started noticing some things in these recording that I had never heard before. Subtle things and pretty amazing that there were these types of improvements. I would have never believed it was possible.
Currently I am running with HQPlayer set at -12db and by passing the volume circuit in the T+A DAC. I also having been leaving the T+A and the STP-SE-2 on with both of their displays turned off. Obviously I am trying to get as clean and pure signal as I possibly can into the SET amplifiers. I can't wait for the Rothwell's to arrive so that I can stop doing any kind of attenuation in software.
At this point I have to say the Stage 2 is the best sounding pre-amplifier that I have ever had.
* The Freya was very good, especially for the price. However the Stage 2 is in a different world.
* The standard STP-SE was very good, but the Stage 2 takes everything to a much higher level.
* I really liked the Audio Research and felt it was wonderful sounding. However the Stage 2 is in a different level of openness, transparency, and sound stage.
* I have had others, and can say in my view they all fall behind these, and way behind the Stage 2.
In my view this is a true world class pre-amp which takes my system to an even higher level of musicality! The bottom end is the best I have ever heard in my system without the use of a sub-woofer!
I am also amazed and a little surprised at how much difference a very good pre-amplifier makes in the performance of a sound system. Logic tells me that running the DAC straight to the amplifiers, especially if the DAC has a very good pre-amp section, should be as good if not better. This is what logic tells me, but my ears have consistently told me that having a good pre-amp in line actually improves the performance. The Wyred 4 Sound STP-SE Stage 2 has cemented that point to an entirely higher level!
