I've considered this piece (not sure I'd go for the Teflon, in the SE...but the 2550 in general).
I'm a big fan of C-J; tried 3 of their pre-amps (ET-2, Premier 18, and ET-3), 2 of their power-amps (MF-2250A and 2500A)...and the
really outstanding, CA-200 "Control" amp.
Ultimately, they weren't quite my cup of tea; but I would never call them, anything less then fantastic. Like a really good movie...and you can appreciate how good it is; even though it's not
exactly your thing.
I gotta tell ya; it's not like, they did a whole lot...in the
style department...as far as updating the look, of the 2550/SE. I'd be hard-pressed, to drop the $4k/6k; when I could buy a MF-2500A in good shape...and send it to C-J for a re-cap.
The thing, was a big, heavy...muscular beast; probably just one notch, below the venerable Premier 350.
Stereophile, logged its numbers...as such:
the MF2500 reached 309W into 8 ohms, one channel driven, and 295Wpc, both channels driven. It wasn't shy at 4 ohms, and the shared power supply was man enough for 451Wpc into 4 ohms. Playing music-related (IHF toneburst) signals, the MF2500 pushed 24.9dBW into 8 ohms (315W) and 24.77dBW into 4 ohms (600W), but began to current-limit a little into 2 ohm loads with 23.9dBW (976W) available.
Oh man; did I just talked myself, into trying it again...for a 3rd time :disbelief: Maybe the only other, better dollar-to-power unit (
excluding class-D, of course)...is its cousin, the McCormack DNA-225/250.
I had the 225 once; what a MONSTER! Here are John's number, on
it...
maximum power raised was 262W into 8 ohms (24.2dBW), 430W into 4 ohms (23.3dBW), and 795W into 2 ohms (23dBW, only one channel driven). With a low-duty-cycle 1kHz toneburst, which generates results that more closely resemble what happens when the amplifier is amplifying music, the DNA-225 was revealed as a powerhouse. No less than 303W were raised into 8 ohms, with 575W available into 4 ohms, 1018W into 2 ohms, and 1532W into 1 ohm. :amazing::whoa::shocking:
