R2R DSD and 48K multiple conversion
shadowlight
Mike or anyone else who has R2R with DSD256 support provided by the R2R, can you potentially run a test for me on your B7 with R2R DSD.
Can you see if you can up convert 48K and it's multiple files to DSD256 (12288000). I am using HQPlayer to do that and I cannot get it to play any 48K files converted to DSD (silence is what I get). Now if I set the maximum rate to 11289600 in HQP everything works, which leads me to believe the R2R DSD does not have support for 48K. Running the same test on chip less DSD128 module that is installed in the B7 I am able to up convert to 6144000 no issues.
TIA
Thx audio.bill, but I do not believe the problem is with HQPlayer. The issue is with the Lampizator R2R DSD. Like I mentioned if I go to the chip less section I am able to play the 48K multiple files up to the DSD128 limit, so something in R2R is preventing playback and I am trying to get confirmation from other Lampi owners to see if they have similar issues or am I special :D
