Shadowfax
Leftover from my days of Custom Machine Design and Building I have a SOLA Constant Voltage Transformer - Harmonic Neutralization Type 120v-240v unit with a Cat# 63-23-125-4
I had it wired for 120v and at one time used it between the wall and Panamax unit. Other than a little use that way, it is basically new and just been sitting inn my workshop for years. It's intended use was for a series of machines we built that had a PC included for the C+ Programming language used to control the machines.
My questions are whether it is a good use for Audio use or not really needed. It does put out a slight Humm and when I did use it shortly I covered it with an insulated box to hide the buzz. I suppose if you had a basement or crawlspace, you could wire it that way to eliminate the noise.
I see they sell from anywhere between $650 and $850 new.
Any feedback would be appreciated.
