aardvarkbark
- Aug 11, 2016
.... Ditto for the 250.
+1
Nooope! I very much like it (and am keeping the Ayre too). It was from the get go intended for my small system in the summerhouse. It will be a killer combo with the Harbeths. Just a quick stop-over in my main system [emoji3].
I think the INT-60 deserves all the praise it is receiving.
I read somewhere that INT-60's pre section may be based on the next generation of Pass pre and not XP-10.
Mike, what are the other two integrated amps on your list of top 3?Congrats! What a great integrated. It's always one of the top 3 on my list for recommendations.
However, I do like the purity of the Pass product. Just the pre+amp sections. No need for a DAC and phono stage on my integrated. Although some would disagree.
That's what I understood too in my conversation with the Pass rep. And he said that it would not get to a volume where clipping would occur. It just does not allow the amp to get louder. Like a throttle control. But there again he could be wrong or I misinterpreted what he said.Could be; but here's a copy of part of an email to me from Pass
Dear Rob
In the case of the INT-60 we are going to see action on the meter that relates to output capability. The meter is going to start to swing right as the Int-60 comes out of pure Class-A operation. By the time the meter wand reaches the right hand side the amp is outputting at least 60 W.
And having said that, if the meter wand is hard right and the signal is not loud enough, then we've simply run out of amplifier wattage
that doesn't necessarily mean the meter is responding to bias changes; Pass may simply have calculated the current value where the amp leaves Class A and set the meter to start responding at that current level, but the end result is the same. The meter starts moving as the amp leaves Class A.
