Odd Playlist Problem
mark090852
Western CO
For the last few days I've been unable to play any of my self developed Qobuz playlists while using the LUMIN app and my D2. I can get the playlist to load, but the songs just start scrolling through the whole list. Each song shows up for about 3 seconds, then it moves on to the next one. None of them actually start playing during this time. It just jumps from one song to another. I have to clear the playlist and then load an album or a track to get the app to play any music. None of my playlists will work. Any suggestions?
Thanks
[QUOTE = mark090852; 267425] Durante los últimos días no he podido reproducir ninguna de las listas de reproducción de Qobuz desarrolladas por mi cuenta mientras uso la aplicación LUMIN y mi D2. Puedo descargar la lista de reproducción, pero las canciones simplemente comienzan a desplazarse por toda la lista. Cada canción aparece durante unos 3 segundos, luego pasa a la siguiente. Ninguno de ellos realmente comienza a jugar durante este tiempo. Simplemente salta de una canción a otra. Tengo que borrar la lista de reproducción y luego cargar un álbum o una pista para que la aplicación reproduzca cualquier música. Ninguna de mis listas de reproducción funcionará. ¿Alguna sugerencia?
Gracias [/ QUOTE]
Lately the application of Lumin is not working well (at least in my Samsung tables) Following the advice of Peter install today Linn Kazoo, seems to work better. Try that app Luck.
Gracias [/ QUOTE]
I really don't want to use a different app. I have always been happy with the LUMIN app, and it has worked very well up until just a few days ago. And it still seems to work fine in all other aspects. It just won't play my playlists.
Please use Lumin app to logout from Qobuz, then re-login again.
Please also verify the internet connection is ok.
I also like the Lumin app, and I would like to continue with the app but as I said more ago a few days ago that is wrong, I can not enter my playlist of Tidal (the app opens the option to restart) in the end I decided to use linn kazoo and everything goes perfectly.
I logged out from Qobuz, and then back in. It helped some. I have five self created playlists and I can play all of them except one. I'm going to delete that one playlist that won't play, and, if everything seems stable with the App, I'll eventually recreate it.
