Kuoppis
- Jan 19, 2015
I don't know how exact I can be, but I will attempt to share my understanding of what they are referring to by "artificially cleaned ground points". Such grounding systems generally attempt to remove noise in the ground, to lower the residual noise in the reference ground point of the system. They do so by effectively filtering the ground to remove undesired noise, but exactly how they accomplish that is not generally shared and likely considered to be proprietary. I have seen some similar products that use a ribbon or plate conductor which is connected to the ground and is immersed in a cavity filled with select rare earth elements which claim to filter noise in the ground. What Nordost refers to as low voltage attractor plates could be referring to such a conductor being used in their filter implementation. I cannot explain the science behind the reactions involved nor to the effectiveness of this type of noise filtering, but am just sharing what I've read about such designs. Nordost's implementation also provides independent clean grounds for the AC power grounds (QKORE1) and the signal grounds (QKORE3). I also found another description (likely also from other Nordost product description) which states: "the Low-Voltage Attractor Plates (LVAPs), constructed with a proprietary metal alloy and a passive electronic circuit, in order to draw stray high frequency noise and voltage-generated magnetic fields to a manufactured earth point, leaving a clean reference behind." Hopefully this additional info is helpful, but of course it doesn't explain their implementation in full detail.
Thank you Bill, appreciate it. What you describe is exactly the point of the experiment.
Most of what you cite, is marketing speak with self-invented words that could mean anything. Therefore it is not really helpful. What becomes evident from it, however, is that the QKore is a purely passive device meant to provide grounding for components. I understand that a proprietary metal alloy might be used to provide grounding, for reason or not. What an electrical circuit should achieve, in a device not being connected to a power outlet, escapes me.
Therefore, I wanted to test what simply grounding the components to a common ground could bring. For this I chose a substantial piece of a very conducting material to connect the devices to. And it obviously achieves something.
Therefore, I really would like to see a tear-down of the QKore to understand what actually is inside. I think one purpose of the excessive pricing is to disincentivise such attempts.
I am not claiming my experiment does what the QKore does, because I don’t know what it does, except to provide grounding. But I even more question the cost of 5,9K w/o cables for the QKore6 in the EU. That might be pretty excessive for what it actually does, if the Nordost grounding wires are to be used as a reference.
